At first, hello and thank you for the great product!
I need to connect to volumio by 4g modem, pluged into raspberry, over web.
I think i’ll do it it by NOIP, and found this solution volumio.github.io/docs/Good_to_ … e_LAN.html
Is it right syntax?
return res.json({ host: ‘http://’+‘myweb.noip.com’});
That’s enough or necessary to install Dynamic Update Client?
noip.com/support/knowledgeb … te-client/
Thanks in advance!
