Connect to the volumio websocket server
I want make test with the volumio’s websocket server.
I install volumio on raspberry pi B, the pi is in a local network on 192.168.xx.xx.
i want run a python script to connect to the volumio websocket server.
import socketio
# standard Python
sio = socketio.Client()
@sio.event
def connect():
    print("I'm connected!")
sio.connect('http://192.168.xx.xx:3000')
sio.wait()
when I run script, I have an error with connection.
i read WebSocket APIs - Volumio Documentation, but i didn’t found the information about connection.
could you help me?
you should do something like
from socketIO_client import SocketIO
def parseStatus(state):
    code to handle
  socketIO = SocketIO('localhost', 3000)
  socketIO.on('pushState', parseStatus)
  socketIO.emit('getState', '', parseStatus)
def main():
	socketIO.wait()
	sleep(0.3)
try:
    main()
except KeyboardInterrupt:
    print("Exiting...")
    pass
I try this code
import Socketio
    code to handle
  socketIO = Socketio('localhost', 3000)
def main():
	socketIO.wait()
	sleep(0.3)
try:
    main()
    print("Exiting...")
    pass
i have an error socketIO about .wait()
an another question is how to connect to an another adresse than localhost?
I try my first scrip on my pi with adress localhost,
i have error
(websocket-env) volumio@volumio:~/websocket$ python essai_connection.py
File “essai_connection.py”, line 14, in
sio.connect(‘http://localhost:3000’)
File “/home/volumio/websocket/websocket-env/lib/python3.7/site-packages/socketio/client.py”, line 338, in connect
raise exceptions.ConnectionError(exc.args[0]) from None
socketio.exceptions.ConnectionError: Unexpected response from server
i believe I started with:
as I expect you’re programming the client side not the server?
hi
I succeeded to connect my voumio.
socketIO.emit('aaa')
socketIO.wait(seconds=1)
i uninstall the python-socketio lib and install socketIO-client lib.
thx you, now I can do my test.
