Confused about breutefir and dsp
I installed the DSP plugin and was having trouble before, but I can’t remember what it was.
I discovered if I removed DSP, the problem went away.
All good.
I am coming now from another angle.
I want to play with REW and found that brutefir would create a sweep and pink noise.
So I followed the link in the volumio instructions and installed it vis SSH from github.
First question, just to clarify is brutefir and the dsp plugin the same thing?
Because I deleted DSP just in case and it seemed like the github brutefir3 instructions installed DSP (even though part of installing it meant I had to agree to the fact that volumio did not support this plugin).
Anyway, I activated the DSP as it had arrived in the plugins section.
Rebooted.
Now it will not start.
I can’t do anything.
I was looking forward to running sweeps etc.
Before I reinstall and do exactly the same thing again, any tips as to what I should do different?
Thanks.
Ouch!
In Volumio3, simply install FusionDsp from the store.
This is the ONLY Dsp plugin supported (up to now).
Read the online help…
I close this thread now. Use the FusionDsp thread for your post.
Thaks
