Every time i enable spotify connect i get this error.
info: Enabling plugin volspotconnect2
info: Loading plugin “volspotconnect2”…
error: Could not copy default configuration to /data/configuration/music_service/volspotconnect2/config.json
info: PLUGIN START: volspotconnect2
[SpotifyConnect] Creating VLS config file
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
[SpotifyConnect] Starting metadata listener
[SpotifyConnect] SpotifyConnect Daemon config issues!
[SpotifyConnect] volspotify config error: [
‘shared = undefined’,
“username = ‘undefined’”,
“password = ‘undefined’”,
‘bitrate = undefined’,
'enable-volume-normalisation = undefined ',
'autoplay = undefined ',
'gapless = undefined ',
[length]: 7
[SpotifyConnect] Error creating SpotifyConnect Daemon config Error: Undefined found found in conf
at ControllerVolspotconnect.createConfigFile (/data/plugins/music_service/volspotconnect2/index.js:610:13)
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volspotconnect2.service
Started Volspotconnect2 Daemon.
[SpotifyConnect] Vollibrespot Daemon service started!
e[34m [Metrics] e[39m SpotifyConnect: e[31m 0s 86.28ms e[39m
info: Done.
vollibrespot v0.2.3 769ce77 2021-06-04 (librespot 08d8bcc 2020-10-07) – Built On 2021-06-04
Unable to read config from “volspotify.toml”, Using default config
[Vollibrespot] : Using Alsa backend with device: default
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: “No such device” }
