LattePanda IOTA Palm-sized x86 Single Board Computer (Intel N150, 8GB RAM / 64GB eMMC)
Wondering if this wonderful looking SBC with a Raspberry Pi RP2040 microcontroller for the 40pin GPIO would be compatible with RPi DAC hats? If not plug and play compatible, what would it take to make it compatible in Volumio? Is there a pin mapping that can be done?
The board in question is x86, it was a reasonable ask given so many RPi DAC / Digi hats available. Unfortunately it won’t work. Thanks for clarifying @wheaten
The touchscreen works right from installation, as does the laptop’s built-in audio.
Volumio is installed on the 32GB eMMC drive inside this HP unit.
The SD card reader also functions as mass storage a 64GB Sandisk SD card was tested.
The Glass plugin also works correctly after installation.
