Can you please explain this in detail? I have intel nuc that will not boot up to USB Drive.
Brand: Acer Aspire One
Model D255
Atom Intel Atom N450 / 1.66 GHz
bootable usb
volumio-2.799-2020-07-16-x86.img
Hi which output are you using for digital audio? I tried to get my white MacBook working with Volumio but could not get the headphone socket digital output to work or be recognised, have you an6 advice please?
Thank you
Take the version from this thread: Volumio X86/ Debian Buster debugging party (BETA) - #205 by sucama, you need to go back to the first post.
And continue your questions from there.
We are very close to a complete new version, x86_386 and x86_amd64.
With the version you find in the mentioned thread you should have more hardware support and will allow me to help further.
This is also valid for people with other failing devices like wifi, eth, usb etc.
Hi thank you. My MacBook has a core 2 duo intel which is 64 bit. Does this help?
please, in the other thread. This one us meant for reporting compatible machines.
Brand: Yukyung
Model: Viliv S5
CPU: Intel Atom Z520
Chipset: (unknown)
Running from local HDD
Image version: volumio-2.878-2021-04-21-x86.img
Note:
Touch screen and integrated wifi/bluetooth not working
In case you are interested, try the Volumio 3 beta from a usb stick, touch screens should work with that.
Thanks. Unfortunately Atom Z520 supports 32-bit only so I would not be able to try the Volumio 3 beta.
P.S. actually I think it is unlikely to work for my machine as the touch screen is implemented using a P/S 2 interface, as far as I know there is no working Linux driver0
Brand: HP
Model: Notebook x2 Detachable 10-p015nz
Booting from: emmc and usb
Intel Atom x5-Z8350 1.44-1.92 GHz quad core processor, 2 W (baytrail)
Onboard sound: Intel SST Audio Device (WDM) with rt5640 codec
Speakers and headphones, automatic switching.
Confirmed image version: 3.101
Booting UEFI (no legacy bios)
Hardware: Giada F210
Processor - Intel® Atom⢠x5-z8350
Chipset - Integrated into CPU
GPU - IntelĀ® HD Graphics
MicrosoftĀ® DirectXĀ® 11
1x VGA, 1x HDMI
Memory - Onboard DDR3L high speed Memory
HDD - Onboard eMMC 8G/32G
1x mSATAII Port for SSD, 1x TF card Slot
RealtekĀ® High Definition Audio
Digital audio via HDMI connector
Intel SST Audio Device (WDM) with es8316 codec (not working yet)
1x Audio out&Mic in jack on the front panel
Brand:MSI
Model: MSI MS-163C (VR601) Laptop(Pentium Dualcore)
Booting From: HDD, USB
Sound Card: Creative x-fi usb 5.1
Volumio 2.916
Brand: Dell
Model: Wyse 3040
Intel Atom X5-Z8350, Quad core 1.44GHz. < 5W power consumption
10/100/1000Mb Rj45 ethernet
3 x USB 2.0, 1x USB 3.0
2 x DisplayPort,
Onboard audio: HDMI, Intel SST Audio Device (WDM) with Realtek RT5672 codec.
1 x composite audio jack: headphone/ mic
(mic unsupported by Volumio)
Volumio 3.179
Recommended WiFi dongle: TP-Link Archer T3U.
Dell E5440 (I3, I5, I7), Booting from SSD/HDD/USB
Dell Inspiron 3180, Booting from eMMC/USB, WL working (No Fanās)
Brand: Chuwi
Model: Larkbox Pro Mini PC
Intel Celeron J4125 4 GB RAM, 128GB eMMC
LAN: no
Wireless: 2.4G/5G, 802.11a/ac/b/g/n Wi-Fi Networking,Bluetooth 5.1
Storage: free m.2 SSD socket
Works with Volumio 3.179, but not to be recommendedā¦
Would have been a nice setup without this annoying and fairly loud fan, pity!
Hi, could you tell me please where can I find a step-by-step procedure? I have the same Acer D255 but the installation procedure stops after login + password.
Thank you
Brand: HP COMPAQ
Model: CQ2012D
Intel Atom D330
USB
Hi I canāt find any answers or solutions about installing pc and booting ssd. It can boot from internal ssd if i intall the program like usb because I want use my fanless pc like core can i do it or it can be.
Burak
Brand: Intel
Model: Intel powered classmate PC
Chipset: Intel Atom N450 (Pinetrail) @ 1.6Ghz (TDP:5.5W)
Ram: 2GB (ddr2)
Audio: Integrated Intel HDA Line Out (Conexant CX20582)
Boot from: Usb and Internal SSD (SanDisk P4 8GB)
Confirmed Image Version: 3.324 (x86_64)
Kernel: 5.10.112-volumio
Lan: Integrated JMicron JMC260 PCI Express Fast Ethernet
Wlan: Realtek RTL8191SEvB
Volumio works great as a headless unit on this baby (No UI out of the box, just tty and ssh).
Kernel detected i915 graphics and eturbotouch Touchscreen.
Steps to make it work, ssh to volumio:
Install Xorg intel driver (sudo apt install xserver-xorg-video-intel)
Create Xorg conf ( /usr/share/X11/xorg.conf.d/10-my.conf)
Section "Device" Identifier "Card0" Driver "intel" EndSection
Create udev rules for touchscreen (/etc/udev/rules.d/91-libinput-eturbotouch-local.rules)
ACTION==āadd|changeā, KERNEL==āevent[0-9]*ā, ENV{ID_VENDOR_ID}==ā22b9ā,
ENV{ID_MODEL_ID}==ā0006ā, ENV{ID_INPUT_TABLET}=āā, ENV{ID_INPUT_TOUCHSCREEN}=ā1ā
Final Result with Now Playing Plugin:
H/W path Device Class Description
system DH110 (To be filled by O.E.M.)
/0 bus FS110
/0/0 memory 64KiB BIOS
/0/3d memory 64KiB L1 cache
/0/3e memory 64KiB L1 cache
/0/3f memory 512KiB L2 cache
/0/40 memory 3MiB L3 cache
/0/41 processor Intel(R) Core⢠i3-6100 CPU @ 3.70GHz
/0/42 memory 4GiB System Memory
/0/42/0 memory 4GiB SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
/0/42/1 memory [empty]
/0/42/2 memory [empty]
/0/42/3 memory [empty]
/0/100 bridge Skylake Host Bridge/DRAM Registers
/0/100/2 display HD Graphics 530
/0/100/14 bus Sunrise Point-H USB 3.0 xHCI Controller
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/5 generic USB2.0-CRW
/0/100/14/0/a multimedia FiiO K5 Pro
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14.2 generic Sunrise Point-H Thermal subsystem
/0/100/16 communication Sunrise Point-H CSME HECI #1
/0/100/17 scsi1 storage Sunrise Point-H SATA controller [AHCI mode]
/0/100/17/0.0.0 /dev/sda disk 120GB SSD Smartbuy 120
/0/100/17/0.0.0/1 /dev/sda1 volume 170MiB Windows FAT volume
/0/100/17/0.0.0/2 /dev/sda2 volume 3452MiB EXT4 volume
/0/100/17/0.0.0/3 /dev/sda3 volume 108GiB EXT4 volume
/0/100/1c bridge Sunrise Point-H PCI Express Root Port #5
/0/100/1d bridge Sunrise Point-H PCI Express Root Port #9
/0/100/1d.1 bridge Sunrise Point-H PCI Express Root Port #10
/0/100/1d.1/0 eth0 network I211 Gigabit Network Connection
/0/100/1f bridge Sunrise Point-H LPC Controller
/0/100/1f.2 memory Memory controller
/0/100/1f.3 multimedia Sunrise Point-H HD Audio
/0/100/1f.4 bus Sunrise Point-H SMBus
/0/100/1f.6 eth1 network Ethernet Connection (2) I219-LM
/0/1 system PnP device PNP0c02
/0/2 communication PnP device PNP0501
/0/3 communication PnP device PNP0501
/0/4 system PnP device PNP0c02
/0/5 system PnP device PNP0c02
/0/6 system PnP device PNP0b00
/0/7 generic PnP device INT3f0d
/0/8 system PnP device PNP0c02
/0/9 system PnP device PNP0c02
/0/a system PnP device PNP0c02
/0/b system PnP device PNP0c02
/1 power To Be Filled By O.E.M.
Boot from: Internal SSD
Confirmed Image Version: 3.378 (x86_64)
Kernel: Welcome to Volumio for x86_64 (5.10.139-volumio x86_64)
ps
On audio everything works, but there are problems with the display of graphics in the web UI (no icons and album art), locally (hdmi) everything is displayed correctly.
