Hello do you Known if this screen IS compatible with volumio ?
Thanks a lot
Thanks a lot
so far i can see it will work…
I had considered this type of display too but, if I pair my DAC, I will see huge RCA cables popping up above
… have you rated this?
yes good… do you know a same version without problem of dac?
I am currently using the TV with HDMI connection but I am evaluating this other solution.
https://community.volumio.com/t/diy-streamer-with-volumio-in-standard-43cm-box
I thought you could use a pin connection cable to position your Dac differently
any full 40 pin cable will do the old pc cables not the one with 1 filled pin in the cable…
