I don’t like the green color in the canvas rings, music-info and volume.
I want to change them to blue or red. Can someone tell me where this green color is defined?
Note: Volumio version 2!
tia,
.Nico
tia,
.Nico
It’s simply not that easy.
Volumio2 uses sass and the CSS is compiled when the UI is built.
Once released you should be able to clone the UI repo, change the volumio green variable and compile your own UI and overwrite the default one on the sd card.
Also rune use blue and moode uses red.
Thanks, I’ll pull it off one of these days…
What I like about v2 is the MultiRoom option and the possibillity to play lossless WMA files.
Rune doesn’t seem to support this…
.Nico
