It would be nice if user scripts could be run from the GUI
A user could place .sh files in a predetermined directory. The web UI would work like the “browse,playlist,play” convention, but instead “browse,runlist,run”. I would initially just want to use scripts to perform simple tasks such as set a series of variables and terminate.
A simple script-running facility might reduce the need to add many additional features, as a user could customize Volumio in a simple but reasonably elegant way.
I don’t see what kind of custom script you would like to run… can you give an example?
Let’s say you put a script somewhere and it’s displayed in the root “browse” view. What would it do for example? Like, playing a custom generated playlist? And the script would manage MPD interaction by itself?
This option would be more important in the future if more of the system setup was driven by variables defined in a user .profile. For instance, a future 10-12 band equalizer would be nice, with the boost/cut for each octave defined in a one-line script. I have also seen scripts described in this forum to do a variety of tasks, including building play lists. Such scripts would allow you to personalize a Volumio receiver for any user or room or speakers/headphones with just one click on the UI.
Now that I have alsaequal running on my 3 Volumio renderers, I can see a concrete use for a GUI initiated script.
My next Volumio project may be a portable unit… a kind of wireless boom box. For this project I can see the utility in having several equalizer contours for a variety of different locations. Alsaequal creates a file /var/lib/mpd/.alasequal.bin to save an equalizer configuration. It is easy to create and save a series of such files. While I could ssh in and manipulate these, it would be nice to do so by running a script from the GUI.
I have a MATRIX toslink switch for audio at home. Volumio is connected to this matrix switch (hifiberry digi) and I could send the audio anywhere in the house from the push of a button in the GUI. Right now, I have to use a separate application. All is needed is a simple script to send an RS232 command to the switch. I could also control the volume in each room separatly (rs232 again, with RS232-to-IR module)
The problem is i’m a software engineer with limited knowledge of Web development. Give me a hook in linux and I’ll build the rest
