Often, but not always, when going from a track with a lower sample rate to a track with a higher sample rate, there will be no output, just “pops and clicks”. For example, first track - 44.1Khz to next track at 192Khz is the way this happens most frequently. Fixing usually involves going to a track with a different sample rate, say 96Khz, then back to the 192Khz. Tested using different external dacs, so its not the DAC. Happens with Qobuz hi-res streaming and also local storage hi-res files.
