Cm4io does not detect JCat XE USB PCI-Express card
hi,
I would like to buy the same jcat card as a friend has.
It doesn’t work with moode or volumio.
please view the logs
[Mod] Removed Moode log to keep forum readable
that’s not a volumio log, so it is no use to anyone.
Remember, this is a forum where community members help members with Volumio issues.
volumio@volumio:~$ sudo dmesg
[sudo] password for volumio:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.92-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gc        c-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34)        #1514 SMP Mon Jan 17 17:38:03 GMT 2022
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Compute Module 4 Rev 1.0
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000002a000000, s        ize 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share        d-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003dffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] On node 0 totalpages: 516096
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 319488 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 514368
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835        .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=640 bcm2708_f        b.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:FE:66:6E vc_mem.mem        _base=0x3ec00000 vc_mem.mem_size=0x40000000  splash plymouth.ignore-serial-conso        les dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_o        tg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2        imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.        global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm28        35.enable_hdmi=1 loglevel=0
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes,        linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li        near)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000024e00000-0x0000000028e0000        0] (64MB)
[    0.000000] Memory: 1881660K/2064384K available (10240K kernel code, 1366K rw        data, 3196K rodata, 2048K init, 882K bss, 117188K reserved, 65536K cma-reserved,        1277952K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 34360 entries in 101 pages
[    0.000000] ftrace: allocated 101 pages with 4 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif        fies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c wit        h crng_init=1
[    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2        147483647500ns
[    0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_        idle_ns: 1911260446275 ns
[    0.000086] bcm2835: system timer (irq = 25)
[    0.000756] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000774] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000793] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980        46511102ns
[    0.000807] Switching to timer-based delay loop, resolution 18ns
[    0.001078] Console: colour dummy device 80x30
[    0.001145] printk: console [tty1] enabled
[    0.001200] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 108.00 BogoMIPS (lpj=540000)
[    0.001232] pid_max: default: 32768 minimum: 301
[    0.001398] LSM: Security Framework initializing
[    0.001586] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea        r)
[    0.001612] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes,        linear)
[    0.003085] cgroup: Disabling memory control group subsystem
[    0.003321] CPU: Testing write buffer coherency: ok
[    0.003782] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004987] Setting up static identity map for 0x200000 - 0x20003c
[    0.005185] rcu: Hierarchical SRCU implementation.
[    0.006114] smp: Bringing up secondary CPUs ...
[    0.007322] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008691] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.009987] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010145] smp: Brought up 1 node, 4 CPUs
[    0.010167] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.010182] CPU: All CPU(s) started in HYP mode.
[    0.010196] CPU: Virtualization extensions available.
[    0.011147] devtmpfs: initialized
[    0.026399] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8        rev 0
[    0.026622] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
[    0.026652] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.028566] pinctrl core: initialized pinctrl subsystem
[    0.029613] NET: Registered protocol family 16
[    0.034124] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.034898] audit: initializing netlink subsys (disabled)
[    0.035160] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=        0 res=1
[    0.035741] thermal_sys: Registered thermal governor 'step_wise'
[    0.036808] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
[    0.036824] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.037235] Serial: AMBA PL011 UART driver
[    0.070984] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090863] raspberrypi-firmware soc:firmware: Attached to firmware from 2022        -01-20T13:56:48, variant start
[    0.100876] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d        34e4e0613a85c7a6d3da49e13e2
[    0.142492] Kprobes globally optimized
[    0.147895] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.152824] vgaarb: loaded
[    0.153298] SCSI subsystem initialized
[    0.153534] usbcore: registered new interface driver usbfs
[    0.153595] usbcore: registered new interface driver hub
[    0.153669] usbcore: registered new device driver usb
[    0.154020] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.156313] clocksource: Switched to clocksource arch_sys_counter
[    1.182732] VFS: Disk quotas dquot_6.6.0
[    1.182837] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.183020] FS-Cache: Loaded
[    1.183203] CacheFiles: Loaded
[    1.192445] NET: Registered protocol family 2
[    1.192688] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line        ar)
[    1.194030] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144        bytes, linear)
[    1.194074] TCP established hash table entries: 8192 (order: 3, 32768 bytes,        linear)
[    1.194233] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.194304] TCP: Hash tables configured (established 8192 bind 8192)
[    1.194477] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.194513] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.194758] NET: Registered protocol family 1
[    1.195552] RPC: Registered named UNIX socket transport module.
[    1.195567] RPC: Registered udp transport module.
[    1.195582] RPC: Registered tcp transport module.
[    1.195597] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.195621] PCI: CLS 0 bytes, default 64
[    1.195875] Trying to unpack rootfs image as initramfs...
[    2.204950] Freeing initrd memory: 13028K
[    2.208348] Initialise system trusted keyrings
[    2.208649] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    2.217049] zbud: loaded
[    2.219348] FS-Cache: Netfs 'nfs' registered for caching
[    2.220120] NFS: Registering the id_resolver key type
[    2.220174] Key type id_resolver registered
[    2.220190] Key type id_legacy registered
[    2.220331] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.220348] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering        ...
[    2.221359] Key type asymmetric registered
[    2.221375] Asymmetric key parser 'x509' registered
[    2.221569] bounce: pool size: 64 pages
[    2.221624] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        49)
[    2.221839] io scheduler mq-deadline registered
[    2.221857] io scheduler kyber registered
[    2.226404] gpio-507 (ant1): hogged as output/high
[    2.227845] gpio-511 (ant2): hogged as output/low
[    2.229398] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    2.229429] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500        000, using [bus 00-ff]
[    2.229510] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0        x00c0000000
[    2.229600] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0        x0400000000
[    2.288418] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    2.288789] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    2.288811] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.288833] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff]        (bus address [0xc0000000-0xffffffff])
[    2.288923] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    2.289168] pci 0000:00:00.0: PME# supported from D0 D3hot
[    2.292807] PCI: bus0: Fast back to back transfers disabled
[    2.293087] pci 0000:01:00.0: [1b21:2142] type 00 class 0x0c0330
[    2.293165] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    2.293298] pci 0000:01:00.0: enabling Extended Tags
[    2.293535] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    2.293627] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by        5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCI        e x2 link)
[    2.297141] PCI: bus1: Fast back to back transfers disabled
[    2.297240] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    2.297264] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600007fff 64        bit]
[    2.297310] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.297336] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    2.297745] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    2.297979] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
[    2.298314] pci 0000:01:00.0: PME# does not work under D0, disabling it
[    2.298348] pci 0000:01:00.0: enabling device (0140 -> 0142)
[    2.299115] bcm2708_fb soc:fb: FB found 1 display(s)
[    2.304832] Console: switching to colour frame buffer device 80x30
[    2.306857] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 640        x480
[    2.315574] iproc-rng200 fe104000.rng: hwrng registered
[    2.315886] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
[    2.317326] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2        00000
[    2.329691] brd: module loaded
[    2.342077] loop: module loaded
[    2.343945] Loading iSCSI transport class v2.0-870.
[    2.347306] libphy: Fixed MDIO Bus: probed
[    2.349077] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    2.366401] libphy: bcmgenet MII bus: probed
[    2.456504] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    2.457695] usbcore: registered new interface driver r8152
[    2.457763] usbcore: registered new interface driver lan78xx
[    2.457825] usbcore: registered new interface driver smsc95xx
[    2.459450] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    2.459487] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 1
[    2.516803] xhci_hcd 0000:01:00.0: hcc params 0x0200ef80 hci version 0x110 qu        irks 0x0000000000800010
[    2.518298] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.10
[    2.518317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    2.518335] usb usb1: Product: xHCI Host Controller
[    2.518352] usb usb1: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
[    2.518368] usb usb1: SerialNumber: 0000:01:00.0
[    2.519120] hub 1-0:1.0: USB hub found
[    2.519192] hub 1-0:1.0: 2 ports detected
[    2.519937] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    2.519965] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 2
[    2.519992] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    2.520172] usb usb2: We don't know the algorithms for LPM for this host, dis        abling LPM.
[    2.520468] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 5.10
[    2.520487] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    2.520503] usb usb2: Product: xHCI Host Controller
[    2.520520] usb usb2: Manufacturer: Linux 5.10.92-v7l+ xhci-hcd
[    2.520536] usb usb2: SerialNumber: 0000:01:00.0
[    2.521195] hub 2-0:1.0: USB hub found
[    2.521265] hub 2-0:1.0: 2 ports detected
[    2.522659] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.522978] dwc_otg: FIQ enabled
[    2.522992] dwc_otg: NAK holdoff enabled
[    2.523006] dwc_otg: FIQ split-transaction FSM enabled
[    2.523024] Module dwc_common_port init
[    2.523503] usbcore: registered new interface driver uas
[    2.523610] usbcore: registered new interface driver usb-storage
[    2.523815] mousedev: PS/2 mouse device common for all mice
[    2.525496] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    2.529045] sdhci: Secure Digital Host Controller Interface driver
[    2.529061] sdhci: Copyright(c) Pierre Ossman
[    2.529804] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    2.530449] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.533706] ledtrig-cpu: registered to indicate activity on CPUs
[    2.534066] hid: raw HID events driver (C) Jiri Kosina
[    2.534259] usbcore: registered new interface driver usbhid
[    2.534274] usbhid: USB HID core driver
[    2.540356] Initializing XFRM netlink socket
[    2.540398] NET: Registered protocol family 17
[    2.540509] Key type dns_resolver registered
[    2.541240] Registering SWP/SWPB emulation handler
[    2.541420] registered taskstats version 1
[    2.541449] Loading compiled-in X.509 certificates
[    2.542319] Key type ._fscrypt registered
[    2.542335] Key type .fscrypt registered
[    2.542350] Key type fscrypt-provisioning registered
[    2.554322] uart-pl011 fe201000.serial: there is not valid maps for state def        ault
[    2.554639] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    2.554716] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud        = 0) is a PL011 rev2
[    2.563759] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive        r
[    2.564838] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    2.564856] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    2.592654] of_cfs_init
[    2.592930] of_cfs_init: OK
[    2.610601] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.612325] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.614049] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.617131] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.618835] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.628230] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    2.639077] Freeing unused kernel memory: 2048K
[    2.639464] Run /init as init process
[    2.639479]   with arguments:
[    2.639494]     /init
[    2.639508]     splash
[    2.639523]   with environment:
[    2.639537]     HOME=/
[    2.639551]     TERM=linux
[    2.639565]     imgpart=/dev/mmcblk0p2
[    2.639579]     imgfile=/volumio_current.sqsh
[    2.639593]     bootdelay=5
[    2.688769] mmc1: new high speed SDIO card at address 0001
[    2.736440] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[    2.737505] mmcblk0: mmc0:0001 ASTC 29.1 GiB
[    2.740190]  mmcblk0: p1 p2 p3
[    2.843101] initramfs: Booting Volumio for BCM2711
[    2.843284] initramfs: This script mounts rootfs RO with an overlay RW layer.
[    2.876787] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.890641] initramfs: IMGPART=/dev/mmcblk0p2
[    2.890805] initramfs: IMGFILE=/volumio_current.sqsh
[    2.891025] initramfs: Boot delay (except first time) will be 5 seconds
[    2.952063] initramfs: /dev/mmcblk0p2:
[    3.047811] EXT4-fs (mmcblk0p2): recovery complete
[    3.048943] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
[    3.051711] initramfs: Doing a 5 second delay here to give kernel load a head        start
[    8.057323] initramfs: Checking for USB updates
[    8.149583] initramfs: No USB device detected (when incorrect, try adding 'bo        otdelay=5' to your boot cmdline)
[    8.962634] EXT4-fs (mmcblk0p3): recovery complete
[    9.042420] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. O        pts: (null)
[    9.046716] initramfs: With Option:
[    9.108929] initramfs: VOLUMIO_VERSION="3.396"
[    9.109109] initramfs: Finish initramfs, continue booting Volumio
[    9.945570] systemd[1]: System time before build time, advancing clock.
[   10.075518] NET: Registered protocol family 10
[   10.077070] Segment Routing with IPv6
[   10.176670] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
[   10.177460] systemd[1]: Detected architecture arm.
[   10.254796] systemd[1]: Set hostname to <volumio>.
[   10.893848] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= refer        ences path below legacy directory /var/run/, updating /var/run/samba/winbindd.pi        d \xe2\x86\x92 /run/samba/winbindd.pid; please update the unit file accordingly.
[   11.105757] random: systemd: uninitialized urandom read (16 bytes read)
[   11.105859] random: systemd: uninitialized urandom read (16 bytes read)
[   11.118437] random: systemd: uninitialized urandom read (16 bytes read)
[   11.159751] systemd[1]: Listening on RPCbind Server Activation Socket.
[   11.161442] systemd[1]: Created slice User and Session Slice.
[   11.161633] systemd[1]: Reached target System Time Synchronized.
[   11.163058] systemd[1]: Created slice system-getty.slice.
[   11.164445] systemd[1]: Listening on udev Kernel Socket.
[   11.165865] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.421408] i2c /dev entries driver
[   11.970427] systemd-journald[201]: Received request to flush runtime journal        from PID 1
[   12.300883] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg        isters at 0xfeb00000 length 0x00010000
[   12.301507] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised        : Registers at 0xfeb10000 length 0x00001000
[   12.302043] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg        isters at 0xfeb20000 length 0x00010000
[   12.302612] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis        ters at 0xfeb30000 length 0x00010000
[   12.403451] mc: Linux media interface: v0.10
[   12.449116] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
[   12.451427] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[   12.451452] [vc_sm_connected_init]: start
[   12.452637] [vc_sm_connected_init]: installed successfully
[   12.693063] videodev: Linux video capture interface: v2.00
[   12.736477] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
[   12.745789] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
[   12.779545] bcm2835_v4l2: module is from the staging directory, the quality i        s unknown, you have been warned.
[   12.864045] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
[   12.866198] bcm2835_audio bcm2835_audio: there is not valid maps for state de        fault
[   12.867792] bcm2835_isp: module is from the staging directory, the quality is        unknown, you have been warned.
[   12.870547] bcm2835_codec: module is from the staging directory, the quality        is unknown, you have been warned.
[   12.882478] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev        /video13
[   12.884322] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[   12.884358] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de        v/video14
[   12.884374] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[   12.888651] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de        v/video15
[   12.889171] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/        video16
[   12.889200] bcm2835-isp bcm2835-isp: Register output node 0 with media contro        ller
[   12.889225] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr        oller
[   12.889327] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr        oller
[   12.889351] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr        oller
[   12.890384] bcm2835_audio bcm2835_audio: card created with 8 channels
[   12.891535] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[   12.891602] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[   12.900745] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev        /video20
[   12.901421] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de        v/video21
[   12.902008] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[   12.902053] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[   12.902103] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de        v/video22
[   12.902445] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/        video23
[   12.902472] bcm2835-isp bcm2835-isp: Register output node 0 with media contro        ller
[   12.902497] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr        oller
[   12.902519] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr        oller
[   12.902542] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr        oller
[   12.902741] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[   12.913445] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[   12.913491] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[   13.280822] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
[   13.340273] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   13.591899] brcmfmac: F1 signature read @0x18000000=0x15264345
[   13.612247] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
[   13.613722] usbcore: registered new interface driver brcmfmac
[   14.058386] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
[   14.059684] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
[   14.096423] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4        2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[   14.211619] wm8804 1-003b: Failed to read device ID: -121
[   14.212361] wm8804: probe of 1-003b failed with error -121
[   15.896188] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[   15.952105] 8021q: 802.1Q VLAN Support v1.8
[   16.329631] uart-pl011 fe201000.serial: no DMA platform data
[   16.501625] bcmgenet fd580000.ethernet: configuring instance for external RGM        II (RX delay)
[   16.502910] bcmgenet fd580000.ethernet eth0: Link is Down
[   18.562541] random: crng init done
[   18.562552] random: 7 urandom warning(s) missed due to ratelimiting
[   20.322886] usb usb2-port2: over-current change #1
[   20.323139] usb usb1-port2: over-current change #1
[   20.636548] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow c        ontrol off
[   21.161604] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[   22.416371] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[   22.416786] ------------[ cut here ]------------
[   22.416801] WARNING: CPU: 0 PID: 244 at kernel/dma/swiotlb.c:718 swiotlb_map+        0x3bc/0x46c
[   22.416810] xhci_hcd 0000:01:00.0: swiotlb addr 0x0000000424e00000+8 overflow        (mask ffffffff, bus limit 47fffffff).
[   22.416816] Modules linked in: nft_counter nft_chain_nat xt_REDIRECT nf_nat n        f_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_tcpudp nft_compat nf_tables nfnetli        nk 8021q garp stp llc snd_soc_wm8804_i2c snd_soc_wm8804 regmap_i2c brcmfmac brcm        util cfg80211 rfkill snd_soc_rpi_wm8804_soundcard snd_soc_bcm2835_i2s snd_soc_co        re bcm2835_codec(C) bcm2835_isp(C) snd_bcm2835(C) snd_compress snd_pcm_dmaengine        snd_pcm bcm2835_v4l2(C) v4l2_mem2mem raspberrypi_hwmon bcm2835_mmal_vchiq(C) vi        deobuf2_vmalloc videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_c        ommon videodev snd_seq snd_seq_device snd_timer i2c_bcm2835 snd vc_sm_cma(C) mc        rpivid_mem nvmem_rmem uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6 squash        fs overlay
[   22.417160] CPU: 0 PID: 244 Comm: kworker/0:3 Tainted: G         C        5.1        0.92-v7l+ #1514
[   22.417164] Hardware name: BCM2711
[   22.417173] Workqueue: usb_hub_wq hub_event
[   22.417180] Backtrace:
[   22.417193] [<c0b87728>] (dump_backtrace) from [<c0b87abc>] (show_stack+0x20/        0x24)
[   22.417200]  r7:ffffffff r6:00000000 r5:60000013 r4:c12e6fd8
[   22.417207] [<c0b87a9c>] (show_stack) from [<c0b8be9c>] (dump_stack+0xcc/0xf8        )
[   22.417215] [<c0b8bdd0>] (dump_stack) from [<c0220d2c>] (__warn+0xfc/0x114)
[   22.417222]  r10:00000008 r9:00000009 r8:c02a68a4 r7:000002ce r6:00000009 r5:        c02a68a4
[   22.417226]  r4:c0e29be4 r3:c1205094
[   22.417233] [<c0220c30>] (__warn) from [<c0b88250>] (warn_slowpath_fmt+0xa4/0        xd8)
[   22.417238]  r7:000002ce r6:c0e29be4 r5:c1205048 r4:c0e29ba0
[   22.417244] [<c0b881b0>] (warn_slowpath_fmt) from [<c02a68a4>] (swiotlb_map+0        x3bc/0x46c)
[   22.417250]  r9:c1bb3070 r8:c1205048 r7:00000000 r6:ffffffff r5:00000000 r4:f        fffffff
[   22.417258] [<c02a64e8>] (swiotlb_map) from [<c02a1300>] (dma_map_page_attrs+        0x254/0x394)
[   22.417264]  r10:00000001 r9:00000008 r8:c1bb31e0 r7:00000000 r6:ffffffff r5:        c1205048
[   22.417268]  r4:c1bb3070
[   22.417275] [<c02a10ac>] (dma_map_page_attrs) from [<c08fb0a4>] (usb_hcd_map_        urb_for_dma+0x1e4/0x55c)
[   22.417281]  r10:ee9d978c r9:00000c00 r8:00000c00 r7:c1bb3070 r6:c2acc8c0 r5:        c2056000
[   22.417285]  r4:ee9d9780
[   22.417293] [<c08faec0>] (usb_hcd_map_urb_for_dma) from [<c0912eb0>] (xhci_ma        p_urb_for_dma+0x38/0x78)
[   22.417299]  r10:ee9d978c r9:00000c00 r8:c2312400 r7:00000200 r6:c1205048 r5:        c2056000
[   22.417303]  r4:ee9d9780
[   22.417310] [<c0912e78>] (xhci_map_urb_for_dma) from [<c08fb4ec>] (usb_hcd_su        bmit_urb+0xd0/0x9c8)
[   22.417317] [<c08fb41c>] (usb_hcd_submit_urb) from [<c08fcd1c>] (usb_submit_u        rb+0x2f0/0x500)
[   22.417322]  r10:c2acc8c0 r9:c0c5afe8 r8:00000c00 r7:00000200 r6:c28b2400 r5:        00000000
[   22.417326]  r4:ee9d9780
[   22.417332] [<c08fca2c>] (usb_submit_urb) from [<c08fdb14>] (usb_start_wait_u        rb+0x6c/0xf0)
[   22.417338]  r10:c2acc8c0 r9:00001388 r8:eea5bd88 r7:eea5bd38 r6:00000000 r5:        c1205048
[   22.417342]  r4:ee9d9780
[   22.417348] [<c08fdaa8>] (usb_start_wait_urb) from [<c08fdc6c>] (usb_control_        msg+0xd4/0x12c)
[   22.417354]  r9:00000006 r8:00000100 r7:00000000 r6:00000040 r5:c28b2400 r4:c        1205048
[   22.417362] [<c08fdb98>] (usb_control_msg) from [<c08f4d78>] (hub_port_init+0        x408/0xc8c)
[   22.417367]  r10:80000080 r9:c12ff7b4 r8:00000000 r7:00000003 r6:c2312400 r5:        c2accc80
[   22.417371]  r4:c28b2400
[   22.417378] [<c08f4970>] (hub_port_init) from [<c08f7d08>] (hub_event+0x850/0        x135c)
[   22.417383]  r10:c231cf00 r9:c2312400 r8:c28b2400 r7:00000001 r6:00000000 r5:        c2056000
[   22.417387]  r4:c205601c
[   22.417394] [<c08f74b8>] (hub_event) from [<c023de7c>] (process_one_work+0x25        0/0x5a0)
[   22.417400]  r10:00000000 r9:00000000 r8:00000000 r7:eff75800 r6:eff706c0 r5:        eedd4680
[   22.417404]  r4:c231cf00
[   22.417411] [<c023dc2c>] (process_one_work) from [<c023e22c>] (worker_thread+        0x60/0x5c4)
[   22.417416]  r10:eff706c0 r9:c1203d00 r8:eff706d8 r7:00000008 r6:eff706c0 r5:        eedd4694
[   22.417420]  r4:eedd4680
[   22.417427] [<c023e1cc>] (worker_thread) from [<c0245d0c>] (kthread+0x170/0x1        74)
[   22.417433]  r10:c193fe74 r9:eedd4680 r8:c023e1cc r7:eea5a000 r6:00000000 r5:        ee809c40
[   22.417437]  r4:eec41fc0
[   22.417444] [<c0245b9c>] (kthread) from [<c02000ec>] (ret_from_fork+0x14/0x28        )
[   22.417448] Exception stack(0xeea5bfb0 to 0xeea5bff8)
[   22.417454] bfa0:                                     00000000 00000000 00000        000 00000000
[   22.417459] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[   22.417464] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   22.417470]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:        c0245b9c
[   22.417474]  r4:ee809c40
[   22.417479] ---[ end trace a5bf1df461700a43 ]---
[   22.566422] usb 1-1: device descriptor read/64, error -11
[   22.836420] usb 1-1: device descriptor read/64, error -11
[   23.540247] Bluetooth: Core ver 2.22
[   23.540316] NET: Registered protocol family 31
[   23.540323] Bluetooth: HCI device and connection manager initialized
[   23.540341] Bluetooth: HCI socket layer initialized
[   23.540351] Bluetooth: L2CAP socket layer initialized
[   23.540368] Bluetooth: SCO socket layer initialized
[   23.550709] Bluetooth: HCI UART driver ver 2.3
[   23.550719] Bluetooth: HCI UART protocol H4 registered
[   23.550779] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   23.550946] Bluetooth: HCI UART protocol Broadcom registered
[   23.698010] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   23.698020] Bluetooth: BNEP filters: protocol multicast
[   23.698033] Bluetooth: BNEP socket layer initialized
[   24.445424] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[   25.136559] usb 1-1: new high-speed USB device number 4 using xhci_hcd
[   25.286511] usb 1-1: device descriptor read/64, error -11
[   25.566483] usb 1-1: device descriptor read/64, error -11
[   27.866471] usb 1-1: new high-speed USB device number 6 using xhci_hcd
[   28.016522] usb 1-1: device descriptor read/64, error -11
[   28.286540] usb 1-1: device descriptor read/64, error -11
[   30.586527] usb 1-1: new high-speed USB device number 8 using xhci_hcd
[   30.736578] usb 1-1: device descriptor read/64, error -11
[   31.006612] usb 1-1: device descriptor read/64, error -11
[   33.116557] cam-dummy-reg: disabling
[   33.116571] cam1-reg: disabling
[   33.306551] usb 1-1: new high-speed USB device number 10 using xhci_hcd
[   33.456641] usb 1-1: device descriptor read/64, error -11
[   33.726692] usb 1-1: device descriptor read/64, error -11
[   36.026600] usb 1-1: new high-speed USB device number 12 using xhci_hcd
[   36.176662] usb 1-1: device descriptor read/64, error -11
[   36.446665] usb 1-1: device descriptor read/64, error -11
[   38.746594] usb 1-1: new high-speed USB device number 14 using xhci_hcd
[   38.897089] usb 1-1: device descriptor read/64, error -11
[   39.166684] usb 1-1: device descriptor read/64, error -11
[   41.466662] usb 1-1: new high-speed USB device number 16 using xhci_hcd
[   41.616738] usb 1-1: device descriptor read/64, error -11
[   41.886737] usb 1-1: device descriptor read/64, error -11
[   44.196669] usb 1-1: new high-speed USB device number 18 using xhci_hcd
[   44.346739] usb 1-1: device descriptor read/64, error -11
[   44.616734] usb 1-1: device descriptor read/64, error -11
[   46.916733] usb 1-1: new high-speed USB device number 20 using xhci_hcd
[   47.066844] usb 1-1: device descriptor read/64, error -11
[   47.336811] usb 1-1: device descriptor read/64, error -11
[   49.636741] usb 1-1: new high-speed USB device number 22 using xhci_hcd
[   49.786795] usb 1-1: device descriptor read/64, error -11
[   50.056803] usb 1-1: device descriptor read/64, error -11
[   52.319854] Bluetooth: RFCOMM TTY layer initialized
[   52.319876] Bluetooth: RFCOMM socket layer initialized
[   52.319897] Bluetooth: RFCOMM ver 1.11
[   52.356835] usb 1-1: new high-speed USB device number 24 using xhci_hcd
[   52.506870] usb 1-1: device descriptor read/64, error -11
[   52.776870] usb 1-1: device descriptor read/64, error -11
[   55.086812] usb 1-1: new high-speed USB device number 26 using xhci_hcd
[   55.236871] usb 1-1: device descriptor read/64, error -11
[   55.506876] usb 1-1: device descriptor read/64, error -11
[   57.806852] usb 1-1: new high-speed USB device number 28 using xhci_hcd
[   57.956916] usb 1-1: device descriptor read/64, error -11
[   58.226918] usb 1-1: device descriptor read/64, error -11
[   60.526888] usb 1-1: new high-speed USB device number 30 using xhci_hcd
[   60.676942] usb 1-1: device descriptor read/64, error -11
[   60.946945] usb 1-1: device descriptor read/64, error -11
[   63.246929] usb 1-1: new high-speed USB device number 32 using xhci_hcd
[   63.396982] usb 1-1: device descriptor read/64, error -11
[   63.666989] usb 1-1: device descriptor read/64, error -11
[   65.967001] usb 1-1: new high-speed USB device number 34 using xhci_hcd
[   66.117057] usb 1-1: device descriptor read/64, error -11
[   66.387030] usb 1-1: device descriptor read/64, error -11
[   68.687001] usb 1-1: new high-speed USB device number 36 using xhci_hcd
[   68.837054] usb 1-1: device descriptor read/64, error -11
[   69.107057] usb 1-1: device descriptor read/64, error -11
[   71.407036] usb 1-1: new high-speed USB device number 38 using xhci_hcd
[   71.557096] usb 1-1: device descriptor read/64, error -11
[   71.827101] usb 1-1: device descriptor read/64, error -11
[   74.127076] usb 1-1: new high-speed USB device number 40 using xhci_hcd
[   74.277128] usb 1-1: device descriptor read/64, error -11
[   74.547148] usb 1-1: device descriptor read/64, error -11
[   76.847112] usb 1-1: new high-speed USB device number 42 using xhci_hcd
[   76.997165] usb 1-1: device descriptor read/64, error -11
[   77.267185] usb 1-1: device descriptor read/64, error -11
[   79.567153] usb 1-1: new high-speed USB device number 44 using xhci_hcd
[   79.717210] usb 1-1: device descriptor read/64, error -11
[   79.987223] usb 1-1: device descriptor read/64, error -11
[   82.287195] usb 1-1: new high-speed USB device number 46 using xhci_hcd
[   82.447271] usb 1-1: device descriptor read/64, error -11
[   82.737266] usb 1-1: device descriptor read/64, error -11
[   85.047290] usb 1-1: new high-speed USB device number 48 using xhci_hcd
[   85.207292] usb 1-1: device descriptor read/64, error -11
[   85.477300] usb 1-1: device descriptor read/64, error -11
[   87.777263] usb 1-1: new high-speed USB device number 50 using xhci_hcd
[   87.947327] usb 1-1: device descriptor read/64, error -11
[   88.217331] usb 1-1: device descriptor read/64, error -11
[   90.527304] usb 1-1: new high-speed USB device number 52 using xhci_hcd
[   90.677361] usb 1-1: device descriptor read/64, error -11
[   90.947368] usb 1-1: device descriptor read/64, error -11
[   93.247337] usb 1-1: new high-speed USB device number 54 using xhci_hcd
[   93.397465] usb 1-1: device descriptor read/64, error -11
[   93.677796] usb 1-1: device descriptor read/64, error -11
[   95.987406] usb 1-1: new high-speed USB device number 56 using xhci_hcd
[   96.157469] usb 1-1: device descriptor read/64, error -11
[   96.437471] usb 1-1: device descriptor read/64, error -11
[   98.747420] usb 1-1: new high-speed USB device number 58 using xhci_hcd
[   98.897492] usb 1-1: device descriptor read/64, error -11
[   99.167512] usb 1-1: device descriptor read/64, error -11
[  101.467452] usb 1-1: new high-speed USB device number 60 using xhci_hcd
[  101.617510] usb 1-1: device descriptor read/64, error -11
[  101.887514] usb 1-1: device descriptor read/64, error -11
[  104.197347] usb 1-1: new high-speed USB device number 62 using xhci_hcd
[  104.357394] usb 1-1: device descriptor read/64, error -11
[  104.627387] usb 1-1: device descriptor read/64, error -11
[  106.927244] usb 1-1: new high-speed USB device number 64 using xhci_hcd
[  107.077288] usb 1-1: device descriptor read/64, error -11
[  107.347289] usb 1-1: device descriptor read/64, error -11
[  109.647157] usb 1-1: new high-speed USB device number 66 using xhci_hcd
[  109.797216] usb 1-1: device descriptor read/64, error -11
[  110.067201] usb 1-1: device descriptor read/64, error -11
[  112.367085] usb 1-1: new high-speed USB device number 68 using xhci_hcd
[  112.517135] usb 1-1: device descriptor read/64, error -11
[  112.787151] usb 1-1: device descriptor read/64, error -11
[  115.087015] usb 1-1: new high-speed USB device number 70 using xhci_hcd
[  115.237065] usb 1-1: device descriptor read/64, error -11
[  115.517074] usb 1-1: device descriptor read/64, error -11
[  117.816982] usb 1-1: new high-speed USB device number 72 using xhci_hcd
[  117.967014] usb 1-1: device descriptor read/64, error -11
[  118.237006] usb 1-1: device descriptor read/64, error -11
[  120.546913] usb 1-1: new high-speed USB device number 74 using xhci_hcd
[  120.696950] usb 1-1: device descriptor read/64, error -11
[  120.966950] usb 1-1: device descriptor read/64, error -11
[  123.266858] usb 1-1: new high-speed USB device number 76 using xhci_hcd
[  123.416936] usb 1-1: device descriptor read/64, error -11
[  123.686909] usb 1-1: device descriptor read/64, error -11
[  125.986824] usb 1-1: new high-speed USB device number 78 using xhci_hcd
[  126.136911] usb 1-1: device descriptor read/64, error -11
[  126.416879] usb 1-1: device descriptor read/64, error -11
[  128.726791] usb 1-1: new high-speed USB device number 80 using xhci_hcd
[  128.876846] usb 1-1: device descriptor read/64, error -11
[  129.146849] usb 1-1: device descriptor read/64, error -11
[  131.446765] usb 1-1: new high-speed USB device number 82 using xhci_hcd
[  131.596822] usb 1-1: device descriptor read/64, error -11
[  131.866841] usb 1-1: device descriptor read/64, error -11
[  134.166752] usb 1-1: new high-speed USB device number 84 using xhci_hcd
[  134.316802] usb 1-1: device descriptor read/64, error -11
[  134.596800] usb 1-1: device descriptor read/64, error -11
[  136.896795] usb 1-1: new high-speed USB device number 86 using xhci_hcd
[  137.047262] usb 1-1: device descriptor read/64, error -11
[  137.316821] usb 1-1: device descriptor read/64, error -11
[  139.616738] usb 1-1: new high-speed USB device number 88 using xhci_hcd
[  139.766783] usb 1-1: device descriptor read/64, error -11
[  140.046826] usb 1-1: device descriptor read/64, error -11
[  142.346714] usb 1-1: new high-speed USB device number 90 using xhci_hcd
[  142.496778] usb 1-1: device descriptor read/64, error -11
[  142.766769] usb 1-1: device descriptor read/64, error -11
[  145.066709] usb 1-1: new high-speed USB device number 92 using xhci_hcd
[  145.216767] usb 1-1: device descriptor read/64, error -11
[  145.486770] usb 1-1: device descriptor read/64, error -11
[  147.786716] usb 1-1: new high-speed USB device number 94 using xhci_hcd
[  147.936774] usb 1-1: device descriptor read/64, error -11
[  148.206776] usb 1-1: device descriptor read/64, error -11
[  150.506715] usb 1-1: new high-speed USB device number 96 using xhci_hcd
[  150.656840] usb 1-1: device descriptor read/64, error -11
[  150.926770] usb 1-1: device descriptor read/64, error -11
[  153.226726] usb 1-1: new high-speed USB device number 98 using xhci_hcd
[  153.376777] usb 1-1: device descriptor read/64, error -11
[  153.646778] usb 1-1: device descriptor read/64, error -11
[  155.946730] usb 1-1: new high-speed USB device number 100 using xhci_hcd
[  156.096780] usb 1-1: device descriptor read/64, error -11
[  156.366791] usb 1-1: device descriptor read/64, error -11
[  158.666751] usb 1-1: new high-speed USB device number 102 using xhci_hcd
[  158.816808] usb 1-1: device descriptor read/64, error -11
[  159.086797] usb 1-1: device descriptor read/64, error -11
[  161.386752] usb 1-1: new high-speed USB device number 104 using xhci_hcd
[  161.536810] usb 1-1: device descriptor read/64, error -11
[  161.806805] usb 1-1: device descriptor read/64, error -11
[  164.106781] usb 1-1: new high-speed USB device number 106 using xhci_hcd
[  164.256831] usb 1-1: device descriptor read/64, error -11
[  164.526833] usb 1-1: device descriptor read/64, error -11
[  166.826800] usb 1-1: new high-speed USB device number 108 using xhci_hcd
[  166.976855] usb 1-1: device descriptor read/64, error -11
[  167.246875] usb 1-1: device descriptor read/64, error -11
[  169.546839] usb 1-1: new high-speed USB device number 110 using xhci_hcd
[  169.696886] usb 1-1: device descriptor read/64, error -11
[  169.966898] usb 1-1: device descriptor read/64, error -11
[  172.276937] usb 1-1: new high-speed USB device number 112 using xhci_hcd
[  172.436948] usb 1-1: device descriptor read/64, error -11
[  172.716991] usb 1-1: device descriptor read/64, error -11
[  175.016901] usb 1-1: new high-speed USB device number 114 using xhci_hcd
[  175.166998] usb 1-1: device descriptor read/64, error -11
[  175.436967] usb 1-1: device descriptor read/64, error -11
[  177.736933] usb 1-1: new high-speed USB device number 116 using xhci_hcd
[  177.887003] usb 1-1: device descriptor read/64, error -11
[  178.156996] usb 1-1: device descriptor read/64, error -11
[  180.456970] usb 1-1: new high-speed USB device number 118 using xhci_hcd
[  180.607029] usb 1-1: device descriptor read/64, error -11
[  180.877035] usb 1-1: device descriptor read/64, error -11
[  183.177027] usb 1-1: new high-speed USB device number 120 using xhci_hcd
[  183.327079] usb 1-1: device descriptor read/64, error -11
[  183.597065] usb 1-1: device descriptor read/64, error -11
[  185.897045] usb 1-1: new high-speed USB device number 122 using xhci_hcd
[  186.047099] usb 1-1: device descriptor read/64, error -11
[  186.317098] usb 1-1: device descriptor read/64, error -11
[  188.617073] usb 1-1: new high-speed USB device number 124 using xhci_hcd
[  188.767127] usb 1-1: device descriptor read/64, error -11
[  189.037126] usb 1-1: device descriptor read/64, error -11
[  191.337103] usb 1-1: new high-speed USB device number 126 using xhci_hcd
[  191.487164] usb 1-1: device descriptor read/64, error -11
[  191.757167] usb 1-1: device descriptor read/64, error -11
[  194.057139] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[  194.207193] usb 1-1: device descriptor read/64, error -11
[  194.477200] usb 1-1: device descriptor read/64, error -11
[  196.777174] usb 1-1: new high-speed USB device number 4 using xhci_hcd
[  196.927228] usb 1-1: device descriptor read/64, error -11
[  197.197235] usb 1-1: device descriptor read/64, error -11
[  199.497207] usb 1-1: new high-speed USB device number 6 using xhci_hcd
[  199.647263] usb 1-1: device descriptor read/64, error -11
[  199.917319] usb 1-1: device descriptor read/64, error -11
[  202.217239] usb 1-1: new high-speed USB device number 8 using xhci_hcd
[  202.377318] usb 1-1: device descriptor read/64, error -11
[  202.647310] usb 1-1: device descriptor read/64, error -11
[  204.947275] usb 1-1: new high-speed USB device number 10 using xhci_hcd
[  205.097330] usb 1-1: device descriptor read/64, error -11
[  205.367337] usb 1-1: device descriptor read/64, error -11
[  207.667309] usb 1-1: new high-speed USB device number 12 using xhci_hcd
[  207.817362] usb 1-1: device descriptor read/64, error -11
[  208.087395] usb 1-1: device descriptor read/64, error -11
[  210.387343] usb 1-1: new high-speed USB device number 14 using xhci_hcd
[  210.537402] usb 1-1: device descriptor read/64, error -11
[  210.807405] usb 1-1: device descriptor read/64, error -11
[  213.107376] usb 1-1: new high-speed USB device number 16 using xhci_hcd
[  213.257433] usb 1-1: device descriptor read/64, error -11
[  213.527435] usb 1-1: device descriptor read/64, error -11
[  215.827411] usb 1-1: new high-speed USB device number 18 using xhci_hcd
[  215.977473] usb 1-1: device descriptor read/64, error -11
[  216.247494] usb 1-1: device descriptor read/64, error -11
[  218.547456] usb 1-1: new high-speed USB device number 20 using xhci_hcd
[  218.697499] usb 1-1: device descriptor read/64, error -11
[  218.967509] usb 1-1: device descriptor read/64, error -11
[  221.267482] usb 1-1: new high-speed USB device number 22 using xhci_hcd
[  221.417540] usb 1-1: device descriptor read/64, error -11
[  221.687543] usb 1-1: device descriptor read/64, error -11
[  223.987516] usb 1-1: new high-speed USB device number 24 using xhci_hcd
[  224.137593] usb 1-1: device descriptor read/64, error -11
[  224.407575] usb 1-1: device descriptor read/64, error -11
[  226.707548] usb 1-1: new high-speed USB device number 26 using xhci_hcd
[  226.857613] usb 1-1: device descriptor read/64, error -11
[  227.127650] usb 1-1: device descriptor read/64, error -11
[  229.427585] usb 1-1: new high-speed USB device number 28 using xhci_hcd
[  229.577638] usb 1-1: device descriptor read/64, error -11
[  229.847644] usb 1-1: device descriptor read/64, error -11
[  232.147617] usb 1-1: new high-speed USB device number 30 using xhci_hcd
[  232.297703] usb 1-1: device descriptor read/64, error -11
[  232.567680] usb 1-1: device descriptor read/64, error -11
[  234.867659] usb 1-1: new high-speed USB device number 32 using xhci_hcd
[  235.017706] usb 1-1: device descriptor read/64, error -11
[  235.287713] usb 1-1: device descriptor read/64, error -11
[  237.587687] usb 1-1: new high-speed USB device number 34 using xhci_hcd
[  237.737739] usb 1-1: device descriptor read/64, error -11
[  238.007753] usb 1-1: device descriptor read/64, error -11
[  240.307718] usb 1-1: new high-speed USB device number 36 using xhci_hcd
[  240.457797] usb 1-1: device descriptor read/64, error -11
[  240.727780] usb 1-1: device descriptor read/64, error -11
[  243.027757] usb 1-1: new high-speed USB device number 38 using xhci_hcd
[  243.177843] usb 1-1: device descriptor read/64, error -11
[  243.447813] usb 1-1: device descriptor read/64, error -11
[  245.747788] usb 1-1: new high-speed USB device number 40 using xhci_hcd
[  245.897859] usb 1-1: device descriptor read/64, error -11
[  246.167850] usb 1-1: device descriptor read/64, error -11
[  248.467827] usb 1-1: new high-speed USB device number 42 using xhci_hcd
[  248.617880] usb 1-1: device descriptor read/64, error -11
[  248.887884] usb 1-1: device descriptor read/64, error -11
[  251.187857] usb 1-1: new high-speed USB device number 44 using xhci_hcd
[  251.337915] usb 1-1: device descriptor read/64, error -11
[  251.607920] usb 1-1: device descriptor read/64, error -11
[  253.907900] usb 1-1: new high-speed USB device number 46 using xhci_hcd
[  254.057950] usb 1-1: device descriptor read/64, error -11
[  254.327953] usb 1-1: device descriptor read/64, error -11
[  256.637927] usb 1-1: new high-speed USB device number 48 using xhci_hcd
[  256.787979] usb 1-1: device descriptor read/64, error -11
[  257.057991] usb 1-1: device descriptor read/64, error -11
[  259.357961] usb 1-1: new high-speed USB device number 50 using xhci_hcd
[  259.508016] usb 1-1: device descriptor read/64, error -11
[  259.778016] usb 1-1: device descriptor read/64, error -11
[  262.077996] usb 1-1: new high-speed USB device number 52 using xhci_hcd
[  262.228050] usb 1-1: device descriptor read/64, error -11
[  262.498061] usb 1-1: device descriptor read/64, error -11
[  264.798035] usb 1-1: new high-speed USB device number 54 using xhci_hcd
[  264.948085] usb 1-1: device descriptor read/64, error -11
[  265.218092] usb 1-1: device descriptor read/64, error -11
[  267.518065] usb 1-1: new high-speed USB device number 56 using xhci_hcd
[  267.668127] usb 1-1: device descriptor read/64, error -11
[  267.938131] usb 1-1: device descriptor read/64, error -11
[  270.238100] usb 1-1: new high-speed USB device number 58 using xhci_hcd
[  270.388163] usb 1-1: device descriptor read/64, error -11
[  270.658161] usb 1-1: device descriptor read/64, error -11
[  272.958138] usb 1-1: new high-speed USB device number 60 using xhci_hcd
[  273.108190] usb 1-1: device descriptor read/64, error -11
[  273.378200] usb 1-1: device descriptor read/64, error -11
[  275.678172] usb 1-1: new high-speed USB device number 62 using xhci_hcd
[  275.828230] usb 1-1: device descriptor read/64, error -11
[  276.098250] usb 1-1: device descriptor read/64, error -11
[  278.398207] usb 1-1: new high-speed USB device number 64 using xhci_hcd
[  278.548274] usb 1-1: device descriptor read/64, error -11
[  278.818263] usb 1-1: device descriptor read/64, error -11
[  281.118257] usb 1-1: new high-speed USB device number 66 using xhci_hcd
[  281.268306] usb 1-1: device descriptor read/64, error -11
[  281.538302] usb 1-1: device descriptor read/64, error -11
[  283.838272] usb 1-1: new high-speed USB device number 68 using xhci_hcd
[  283.988336] usb 1-1: device descriptor read/64, error -11
[  284.258333] usb 1-1: device descriptor read/64, error -11
[  286.558310] usb 1-1: new high-speed USB device number 70 using xhci_hcd
[  286.708364] usb 1-1: device descriptor read/64, error -11
[  286.978366] usb 1-1: device descriptor read/64, error -11
[  289.278350] usb 1-1: new high-speed USB device number 72 using xhci_hcd
[  289.428402] usb 1-1: device descriptor read/64, error -11
[  289.698400] usb 1-1: device descriptor read/64, error -11
[  291.998382] usb 1-1: new high-speed USB device number 74 using xhci_hcd
[  292.148434] usb 1-1: device descriptor read/64, error -11
[  292.418439] usb 1-1: device descriptor read/64, error -11
[  294.718413] usb 1-1: new high-speed USB device number 76 using xhci_hcd
[  294.868466] usb 1-1: device descriptor read/64, error -11
[  295.138471] usb 1-1: device descriptor read/64, error -11
[  297.438452] usb 1-1: new high-speed USB device number 78 using xhci_hcd
[  297.588508] usb 1-1: device descriptor read/64, error -11
[  297.858802] usb 1-1: device descriptor read/64, error -11
[  300.158481] usb 1-1: new high-speed USB device number 80 using xhci_hcd
[  300.308541] usb 1-1: device descriptor read/64, error -11
[  300.578546] usb 1-1: device descriptor read/64, error -11
[  302.878516] usb 1-1: new high-speed USB device number 82 using xhci_hcd
[  303.028577] usb 1-1: device descriptor read/64, error -11
[  303.298581] usb 1-1: device descriptor read/64, error -11
[  305.598554] usb 1-1: new high-speed USB device number 84 using xhci_hcd
[  305.748612] usb 1-1: device descriptor read/64, error -11
[  306.018616] usb 1-1: device descriptor read/64, error -11
[  308.318593] usb 1-1: new high-speed USB device number 86 using xhci_hcd
[  308.468650] usb 1-1: device descriptor read/64, error -11
[  308.738663] usb 1-1: device descriptor read/64, error -11
[  311.038636] usb 1-1: new high-speed USB device number 88 using xhci_hcd
[  311.188677] usb 1-1: device descriptor read/64, error -11
[  311.458692] usb 1-1: device descriptor read/64, error -11
[  313.758660] usb 1-1: new high-speed USB device number 90 using xhci_hcd
[  313.908727] usb 1-1: device descriptor read/64, error -11
[  314.178717] usb 1-1: device descriptor read/64, error -11
[  316.478697] usb 1-1: new high-speed USB device number 92 using xhci_hcd
[  316.628749] usb 1-1: device descriptor read/64, error -11
[  316.898751] usb 1-1: device descriptor read/64, error -11
[  319.198728] usb 1-1: new high-speed USB device number 94 using xhci_hcd
[  319.348783] usb 1-1: device descriptor read/64, error -11
[  319.618790] usb 1-1: device descriptor read/64, error -11
[  321.918772] usb 1-1: new high-speed USB device number 96 using xhci_hcd
[  322.068820] usb 1-1: device descriptor read/64, error -11
[  322.338823] usb 1-1: device descriptor read/64, error -11
[  324.638798] usb 1-1: new high-speed USB device number 98 using xhci_hcd
[  324.788854] usb 1-1: device descriptor read/64, error -11
[  325.058855] usb 1-1: device descriptor read/64, error -11
[  327.358836] usb 1-1: new high-speed USB device number 100 using xhci_hcd
[  327.508894] usb 1-1: device descriptor read/64, error -11
[  327.778894] usb 1-1: device descriptor read/64, error -11
[  330.078892] usb 1-1: new high-speed USB device number 102 using xhci_hcd
[  330.228927] usb 1-1: device descriptor read/64, error -11
[  330.498935] usb 1-1: device descriptor read/64, error -11
[  332.798904] usb 1-1: new high-speed USB device number 104 using xhci_hcd
[  332.948959] usb 1-1: device descriptor read/64, error -11
[  333.218971] usb 1-1: device descriptor read/64, error -11
[  335.518941] usb 1-1: new high-speed USB device number 106 using xhci_hcd
[  335.669002] usb 1-1: device descriptor read/64, error -11
[  335.939006] usb 1-1: device descriptor read/64, error -11
[  338.238985] usb 1-1: new high-speed USB device number 108 using xhci_hcd
[  338.389030] usb 1-1: device descriptor read/64, error -11
[  338.659037] usb 1-1: device descriptor read/64, error -11
[  340.959010] usb 1-1: new high-speed USB device number 110 using xhci_hcd
[  341.109064] usb 1-1: device descriptor read/64, error -11
[  341.379069] usb 1-1: device descriptor read/64, error -11
[  343.679051] usb 1-1: new high-speed USB device number 112 using xhci_hcd
[  343.829101] usb 1-1: device descriptor read/64, error -11
[  344.099138] usb 1-1: device descriptor read/64, error -11
[  346.399087] usb 1-1: new high-speed USB device number 114 using xhci_hcd
[  346.549146] usb 1-1: device descriptor read/64, error -11
[  346.819143] usb 1-1: device descriptor read/64, error -11
[  349.119116] usb 1-1: new high-speed USB device number 116 using xhci_hcd
[  349.269173] usb 1-1: device descriptor read/64, error -11
[  349.539181] usb 1-1: device descriptor read/64, error -11
[  351.839151] usb 1-1: new high-speed USB device number 118 using xhci_hcd
[  351.989214] usb 1-1: device descriptor read/64, error -11
[  352.259228] usb 1-1: device descriptor read/64, error -11
[  354.559193] usb 1-1: new high-speed USB device number 120 using xhci_hcd
[  354.709243] usb 1-1: device descriptor read/64, error -11
[  354.979263] usb 1-1: device descriptor read/64, error -11
volumio@volumio:~$
this is a dump from the dmesg command on volumio
Please post the log, as described here.
http://logs.volumio.org/volumio/r70YZo1.html
How do you power the card, as I see a lot errors which indicates a power failure?
Jan 06 23:05:36 volumio kernel: usb 1-1: new high-speed USB device number 32 using xhci_hcd
Jan 06 23:05:36 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:37 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:39 volumio kernel: usb 1-1: new high-speed USB device number 34 using xhci_hcd
Jan 06 23:05:39 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:42 volumio kernel: usb 1-1: new high-speed USB device number 36 using xhci_hcd
Jan 06 23:05:42 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:44 volumio kernel: usb 1-1: new high-speed USB device number 38 using xhci_hcd
Jan 06 23:05:44 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:45 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:47 volumio kernel: usb 1-1: new high-speed USB device number 40 using xhci_hcd
Jan 06 23:05:47 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:50 volumio kernel: usb 1-1: new high-speed USB device number 42 using xhci_hcd
Jan 06 23:05:50 volumio kernel: usb 1-1: device descriptor read/64, error -11
Jan 06 23:05:53 volumio kernel: usb 1-1: new high-speed USB device number 44 using xhci_hcd
Jan 06 23:05:53 volumio kernel: usb 1-1: device descriptor read/64, error -11
he has by CM4 12V 3A and by Jcat USB 5V 3A
So the card is powered by with external power supply?
If so I have no suggestion. As JCAT doesn’t mention which kernels are support. I do see a lot of mixed reports for this card running on Linux
I wanted to buy this card. A friend supplies a separate power supply, but you can use the cm4io power supply. Can you change kernels and add patches in volumio? How to make the card work?
Please help
https://jcat.eu/featured/usb-card-xe/
I can’t tell, I don’t do kernel patches for Volumio.
But still the same question, patch the kernel to what, there is no info available.
Seems the combo isn’t working:
https://forums.raspberrypi.com/viewtopic.php?t=343511
This is our post raspberry forum.
@gkkpch , @volumio
Any thought?
We don’t patch the raspberry kernel, Volumio takes it as-is.
So the chance to get this working is nil, until Raspian OS supports it.
I’ve been googling a bit, this device raised a number of questions from people asking how to get this to work on the x86 platform. No mention of Raspberry or CM4IO in particular.
My suggestion: follow the issue on the raspberry forum, there you have a bigger chance to get information than here.
Thank you both. I won’t buy it now.
