I have a “CM4/IO board” based setup and just added a Waveshare 5" LCD display (DSI), which is not working. This is System version 3.569 and the touch display plugin is installed. If I transfer the SD card and display to an RPI 4b, the display works. I have tried a fresh installation and reinstalling the plugin, but so far have had no luck. The display is connected to disp1 (have tried disp0) and shows a brief flicker on startup. Are there any special tweaks required for the CM4? I will reach out to Waveshare after New Year’s but thought I would ask here in the meantime.
