Clone Volumio to a New Raspberry PI
I’m very happy with my Volumio running on a RPI at home. I’ve configured it with a number of URL web radio stations. I would like to create a new RPI to use at my cottage which includes these customizations. I need to change the network settings on the new RPI.
I wondering if someone can advise on the best way to accomplish this. I know I can use RPI SD Clone to clone the uSD card but can I then manually change the network settings by mounting the uSD card? I saw there is a SAVE for configuration but it doesn’t seem to save to my computer. Can I export the settings?
Yes—both approaches (Backup/Restore and “clone + edit network files”) are valid and will give you a second Volumio instance with the same web-radio URLs. Here’s a quick sanity-check and a few refinements:
1. Backup/Restore method
  1. Backup on the original Pi
    • In Volumio’s Web UI → Settings → My Music → Backup, click “Start backup.”
    • Volumio packages all user-level settings (web-radio URLs, playlists, plugin configurations and the contents of /data/network) into a single .tar file.
    • Download that .tar to your computer.
  2. Fresh install on the new Pi
    • Flash the same Volumio version to the new SD card.
    • Boot the new Pi and let Volumio complete its initial setup (it can stay on DHCP/Wi-Fi temporarily).
  3. Restore on the new Pi
    • In Volumio’s Web UI → Settings → My Music → Backup, choose your downloaded .tar under “Restore” and click “Restore.”
    • Volumio will import everything and reboot.
  4. Overwrite network settings
    • After restore, go to Volumio’s Web UI → Settings → Network → Wi-Fi (or Ethernet) and change SSID/password or switch to a static IP.
    • Click “Save” (and “Reconnect” if prompted).
• Why it’s correct: The backup file already contains your original network config, so restoring it automatically brings over your home SSID/password. After restore, you simply overwrite those saved credentials with your cottage network’s details.
• Common pitfalls:
  • Make sure both Pis run the same Volumio build (e.g. v3.x). A backup from v3.812 should be restored onto another v3.812 (or at least v3.x) install.
  • If you restore onto a Pi with a very different hardware setup (e.g. moving from RPi3 to RPi4), Volumio will adapt but plugins that are architecture-specific might need re-enabling.
2. Clone SD and manually edit network files
  1. Clone the working SD card
    • Use your preferred imaging tool (Win32 Disk Imager, dd, balenaEtcher, Raspberry Pi Imager, etc.) to create an exact image of the original Volumio SD.
    • Write that image onto the new SD for the cottage Pi.
  2. Mount the root (ext4) partition on your computer
    • The Volumio image has two partitions: a small FAT “boot” slice and a larger ext4 “root” slice.
    • Mount only the ext4 partition (it usually shows up as /dev/sdX2 on Linux). On macOS you’ll need an ext4-capable driver or mount tool.
  3. Edit the Wi-Fi or Ethernet JSON
    • For Wi-Fi, open
      /mnt/volumio/data/network/wpa_supplicant.conf
      and replace the SSID/PSK block with your cottage SSID and password.
    • If you need a static IP (instead of DHCP), edit
      /mnt/volumio/data/configuration/system_controller/network.json
      and set
        "mode": "wifi",
        "ssid": "Cottage_SSID",
        "key": "CottagePassword",
        "ip_method": "static",
        "address": "192.168.2.50",
        "netmask": "255.255.255.0",
        "gateway": "192.168.2.1",
        "dns": "8.8.8.8"
      (or adjust the "mode" and JSON keys appropriately for a wired interface).
  4. Unmount and boot
    • sudo umount /mnt/volumio (or equivalent).
    • Insert the SD into the cottage Pi and power on. It will use the new network block you just wrote.
• Why it’s correct: Cloning gives you an exact OS+configuration copy (including your web-radio entries). By modifying /data/network/... before first boot, you force it to connect to the correct Wi-Fi or Ethernet settings.
• Common pitfalls:
  • If you forget to edit the JSON or wpa_supplicant.conf, the Pi will either try to join your home network (and fail) or drop to AP mode.
  • Make sure any JSON edits remain valid (no missing commas or braces). A malformed network.json will prevent Volumio from parsing it.
Summary
  • Yes, exporting via Volumio’s Backup/Restore is the simplest way to replicate web-radio URLs and other settings. Once restored, just change the network panel in the UI.
  • Yes, you can also “clone + mount + edit” the SD card if you prefer a bit-for-bit copy; just make sure you edit /data/network/wpa_supplicant.conf and/or /data/configuration/system_controller/network.json before the first boot.
Either procedure is correct. Choose Backup/Restore for ease and reliability, or SD-clone + manual edit if you want to preserve absolutely everything at once without using Volumio’s GUI backup.
Why all this complexity???
Just clone the SD with programs like win32diskimager.
Flash the cloned image to a new SD.
Boot the SD on the new location and configure the network.
True—cloning with Win32 Disk Imager is the quickest route if you don’t mind logging in later and re-entering the new network settings.
The reason I described the backup/restore and “clone + edit network files” methods is that the original poster wanted a Pi that boots head-less at the cottage with all web-radio presets and the correct Wi-Fi credentials already baked in. Cloning alone won’t do that unless you edit the network files afterward; backup/restore achieves it with a couple of clicks via the UI.
So both options are on the table—simple clone for convenience, or the slightly more involved path for those who enjoy a bit of tinkering (and want everything to “just work” on first boot). Sometimes tackling the extra complexity is half the fun.
Thanks all.
What I did in the end was:
  • Copy the URL’s of my custom stations
  • Make a new Volumio SD card
  • Boot and configure the new network
  • Manually copy/paste the URL’s of my custom stations
One question is how does one access Volumio to get to the .tar file? SSH is not enabled on my setup,
Go to yoursystemsipaddress/dev and the ssh option is there.
Sorry, don’t understand “yoursystemsipaddress/dev”. At the present time, the Volumio doesn’t have SSH running on port 22.
Accessing Your Volumio Device via Browser:
  1. Open your web browser.
  2. Navigate to your Volumio device.
  3. Add /dev in the address bar.
  • Example: If your IP address is 192.168.1.100, navigate to 192.168.1.100/dev.
Important Reminder:
If these steps seem confusing or difficult, you might want to reconsider following Xone’s instructions, as they involve more complex processes
That makes sense. I didn’t know that the /dev would take me to a menu to enable SSH. That works but any idea what the SSH password is?
User: volumio
password: volumio
