I Have the same behaviour, I set up generic I2S device and use SRC4194(24bits I2S on input and output) and PCM1792 DAC’s. I am preety sure that reason is pause - then volumio goes into I2S sleep?? shitty sample rate? When track is played then everything working fine even there are break in to the track.
When I manually switch to next track is the same when it is made automaticly- everything is fine
Any body solve this problem or maybe has an idea what to do?
I do have the same problem with my setup. I am running a SRC4192 reclocker module (metronome) from Twisted Pear Audio. That is passed on to a PCM1794a DAC (COD DAC) also from Twisted pear audio. I am using a RPI 3 with a Isolator Pi.
I have tried with different drivers and still the same. I do believe this is a hardware problem with the SRC4192. I found this thread on the TI community where there is the following answer:
