CLI Interface ?
Not sure if this is the correct forum to post this in but I did a brief search and didn’t see anything.
Is there a CLI interface to Volumio. Specifically I’d like to have a cron job be able to have a playlist start at a specific volume level. This would be a workaround until an “Alarm” function is added to the system.
I haven’t looked at anything but the web interface so far but if some kind soul would point me in the right direction I’ll take it from there.
Thanks in advance,
Rich
afaik a CLIinterface is not available.
But you can “ssh” in (opensshserver is implemnted.
The standard users are
root
pw: volumio
volumio
pw: volumio
so you could edit your crontab.
Maybe this is a workaround…
Sorry but I have no answer for you, only a question
I am interessted in the same thing. Unfortunately I was not able to find the right commands.
If you log on via ssh you can type “volumio” at the prompt and you get a list of CLI commands. But when I use one of the CLI commands I get an error message.
My Question: Where you able to start “Volumio” at a certain time and start playing a certain radio station or mp3 file?
If yes: Can share your experience with us how it was done.
I am running “Volumio 2”
Thank you very much. I really appreciate if you can share your experience with us.
