At one point I favorited the top level folder of my music library, which recursively added thousands of tracks to my favorites list. Just loading page downloads 200MB of data from volumio and takes forever, and removing any entry from it takes tens of seconds, and can’t be batched as far as I can tell. Unfavouriting everything on the list one by one is a nonstarter, it would take weeks.
I found the favorites list in /data/favourites, this file is 10MB for me, and every time I remove it or reset it to [] it gets repopulated. This happens even if the volumio app is shut down, when I restart the app it repopulates this file.
Is it backing this list up on MyVolumio? Is it stored somewhere else?
I have the same issue. I need to delete all my favourites and it is very time consuming to do it one at a time. Is there a way to delete them all at once?
This may be the worst solution to this problem but it (mostly) worked for me. I wrote a python script that uses the api to individually remove favorites in a loop, and let it run for a couple weeks. Note this was back on volumio 2 and the api may have changed. Replace 192.168.1.207 with the ip of one of your volumio instances.
#!/usr/bin/python3
import time
from socketIO_client import SocketIO
import json
import logging
logging.getLogger('socketIO-client').setLevel(logging.DEBUG)
logging.basicConfig()
sio = SocketIO('192.168.1.207', 3000)
def on_push_state(*args):
global status
status = args[0]['status'].encode('ascii', 'ignore')
print(status)
def on_response(*args):
print("in response")
print(args)
def onGetFavourites(*args):
print("Got favourites")
print(args)
def on_toast(*args):
print("Got toast")
print(args)
favourites = {}
removalRunning = False
def removeTracksFromFavourites(tracks):
global removalRunning
if removalRunning:
return
removalRunning = True
uris = list([t["uri"] for t in tracks])
for u in uris:
print(u)
sio.emit("removeFromFavourites",{
"uri": u,
"service": "mpd"
}, on_response)
sio.wait(seconds=0.5)
def onPushBrowseLibrary(*args):
print("Got Library")
global favourites
favourites = args[0]["navigation"]["lists"][0]["items"]
print(len(favourites))
open('/tmp/vf.json','w').write(json.dumps(favourites))
removeTracksFromFavourites(favourites)
sio.on("pushToastMessage", on_toast)
sio.on('removeFromFavourites', on_response)
sio.on('pushState', on_push_state)
sio.on('pushBrowseLibrary', onPushBrowseLibrary)
#sio.emit('getState', '', 'lol')
def getFavourites():
print("Getting Favourites")
sio.emit("browseLibrary",{
"uri": "favourites",
}, on_response)
sio.emit("pushQueue", [], on_response)
def gettracks():
tracks = []
with open('/tmp/tracks', 'r') as f:
for t in f.read().split('\n'):
tracks.append('mnt/' + t)
return tracks
def main():
getFavourites()
tracks = gettracks()
for t in tracks:
print(t)
"uri": t,
"service": "mpd"
}, on_response)
sio.wait(seconds=1)
sio.wait()
if __name__ == "__main__":
main()
