I’m having a strange behaviour in my library and rescan isn’t doing what is supposed (clean and rebuild library: doesn’t clean).
How can I clean library by hand (SSH or other means), to make volumio new source update?
Happy New Year!
Happy New Year!
Hi @pjorgenunes
As far as I know /var/lib/mpd/tag_cache is your database.
You could SSH into volumio and delete the tag_cache file with
sudo rm /var/lib/mpd/tag_cache
Reboot your system
This seems to remove the database but not the source. so…
Goto sources and just click update.
Ive have just tried this on a test instalation of 3.569 and has the desired effect for me. All working again after the update.
Good luck
Thank you. I’ll try that later and give feedback.
BR,
Paulo
It worked!
Thanks.
Afterall I really had some duplicate songs on a temp folder in my usb drive! OMG!
I had the same problem, and noticed that using a Mac there were a lot of hidden files in an hidden .trash directory and these were the duplicates. Just connected my library drive to windows with hidden files visible and deleted them. Now all is alraight
