Thank you so much SonosKiller, it works like a breeze !!!
Only 1.65TB to go…
The support of the community is wonderfull, and Volumio is always improving, I remeber starting with the first release of the ancient name of volumio…
Once again thanks SonosKiller.
Edit: few hours later…
But, you noticed that a simple x3 letters word can mess with your hapiness… , the share is mounted, I started the update but nothing visible,…
The scan doesn’t work. (few hours later)
I can browse from main screen, then choose NAS, I can see my share… but no directory bellow nor mp3 file…
(I’m listening to some mp3 from that share on my PC using same credentials)
I guess there’s something to add with “Options” more to “vers=1.0”
