info:
DISPLAY=:0 xrandr --output HDMI-1 --rotate right
DISPLAY=:0 xrandr --output HDMI-1 --rotate left
DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
To reset rotation back to normal, use the command:
DISPLAY=:0 xrandr --output HDMI-1 --rotate normal
I’m new, maybe I put the post wrong, but it will help many users, in rotating the image with this driver, please be understanding…
Darmur you are probably right, of course you can skip step 5, if this is the last version of volumio released 2023.03.30, with older versions strange things happen with this display, it is possible that it is about the kms driver.
if you like, the lcd is a touch panel, I turned it off completely, volumio can be controlled by the phone, or add an IR Remote, it is not nice when felt with fingers I pasted it with liquid bitumen, on 2mm aluminum, because it is slightly transparent, now black is black
gluing it on aluminum has an additional positive effect, without it the LCD was getting warm, now this effect has disappeared, I think it will extend its life many times over.
