currently installed 2.129 on x86
the is a newer version avaible
but when i hit Check Updates, nothing happens?
can i do a mannually update?
apt-get update
apt-get upgrade
apt-get update
restart and try to use WebGui
This is at best the worst thing to do. Volumio definetely allows you to upgrade, but you will most likely break your system
If I am so wrong I would like to apologize for this statement, so please what would you suggest!?
