Hi together,
on my Volumio-Pi ist also a picoreplayer running. The Problem ist, that both webinterfaces are using the same port (80). Can anybody tell me, how i can change the Webinterface port (either volumio or picoreplayer)?
Thank you
Hi together,
Thank you
Hi
Same problem here. Two interfaces running on 80 port. Did’n t found yet any easy setup for that.
Any help please?
cheers
cb
