Volumio Information
Volumio Version:2.773
Hardware: RPi3
DAC:-
Hello.
since the latest update I can’t control the volume.
In my internet browser I can change the volume with the volume bar - that’s working.
Changing the volume with the “+” or “-” on the Iphone or internet browser on Mac isn’t working anymore. I didn’t change any of my configurations since the update.
“journalctl” says:
May 30 15:58:55 volumio volumio[1024]: info: VolumeController::SetAlsaVolume+
May 30 15:58:55 volumio volumio[1024]: error: Cannot get ALSA Volume: Error: Alsa Mixer Error: failed to parse output
“config” says:
volumio@volumio:~$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
include userconfig.txt
“aplay” says:
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 5: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Hope you can help me.
