Hi.
I need some help changing the port that the webui uses. Default is port 80.
I’m trying to access volumio over the web. But I got other things on my network that already uses port 80.
(I’ve disabled the other machine that uses 80 and then I can access volumio without problems. But I need that machine for other things)
Just change the port via the nginx configuration file which sits at
/etc/nginx/sites-available/
i’m getting the same problem, but it’s not easy for a newbie to config the script.
nginx it’s been a nightmare for me. Any help will be very appreciated!
cheers
cb
