Change order of web radio favorites?
As the title/topic says. Can’t find anything in the community forums about this and can’t figure it out. I would like to re-order the Web Radio favorites. Worst case, I’ll remove them all and reselect them in my preferred order but as good as the product is, there’s probably something that I’m missing.
Thanks for your assistance!
or you go to the file and re-order them there it should be in :slight_smile:
cd /data/favourites
Greetings, dvo. Sigh. I found the file /data/favourites/radio-favourites
Changing the order of the contents doesn’t seem to make a difference - the web interface puts them in alphabetical order. Thanks, as always, for your quick and helpful reply.
a. b. c. d. or maybe 1. 2. 3. 4. before in the title? maybe we could trick it a bit…
I thought about that - didn’t know if the title needed to match the source database. I’ll give it a whack. Thankn you.
always thinking outside the box …instead of in the box…
i don’t think it has to match, url should be the same but the title who cares… lol
0#-at the beginning of each title entry did the trick. Another win for you!
Best!
glad it worked :stuck_out_tongue:
