Simple solution. Every Rivo user has a premium account.
And then everything works.
thanks for reporting that
could you please explain how you solved it?
I didn’t solve the problem…
OK, sorry I misunderstood your statement
A fix has been implemented in the latest test version
if you want to try it, please enable test-mode from the /dev page and then perform an OTA update
please disable test mode after updating your system
CD Read more… is ok, Album credits and Artist story only Premium
Tidal – Artist story only Premium
Local files is ok
I bought Rivo and I am not a premium user
it’s sad
did you update to the latest test version 3.641, after enabling test mode?
@volumio please have a look
After updating to 3.661, metadata still doesn’t work.
Please fix it!
http://logs.volumio.org/rivo/ti5T4fd.html
@volumio still to be fixed
Local files is ok
Tidal is not working
