Hopefully this is the right category for my question. Apologies if its not.
I am looking for a 3D print design (or a ready to buy case) for a Raspberry pi 5 case. I have the current setup:
Rpi5
Hifiberry DAC2 HD
Geekworm X1002 M.2 Bottom
Does anyone know a case or can anyone help me create a 3D design? I am also very open to suggestions on using another m.2 board but i want to keep the hifiberry dac2 hd if possible
The easiest and cheapest solution is an open case that consists of two acrylic sheets with standoffs. The sides are open; the sheets go on the top and bottom. With the right standoff hardware you can easily accommodate everything. You can buy cases like this from Amazon and many other web sites. You may need some extra hardware depending on where you want to put the M2 board. These cases sell for well under $10. The aesthetic is extreme utilitarian but the open sides are a functional plus with a Pi 5.
