caricare cartelle file musica su hd interno al pc , partizione ext4
invece di utilizzare hd usb , si puo utilizzare hd interno al PC x storare la musica?
google translate ita to eng :
upload music file folders to the PC’s internal HD, ext4 partition
instead of using USB HD, can you use the PC’s internal HD to store music?
Yes you can if you connect Volumio to the share holding your music.
