I was trying to upgrade from 2.118 to 2.129 several times but never success.
Click “Upgrade” I can have the WebGUI show the progress and success information.
However, after click the “Restart” nothing updated. The version still remain in 2.118 and click the “Upgrade” I can still have the find new update information.
I went over and over the same procedure for more then 5 times and never get the system up to date.
Same issue. Advised updated successfully but when the Pi restarts, it still shows 2.118 (and all the wonderful issues such as playback randomly stopping every three songs still exist).
Won’t upgrade to 2.141 either. Tried the suggested shutdown / restart and no difference. Looks as if a re-flash and start again required. Bit of a nuisance since have two Pi’s on 2.118.
Same problem with a Raspberry Pi 3. Can’t upgrade from 2.141 to 2.163. System says “Successfully Updated to 2.163 Version. System Restart is required.” After restart, I have the same old version.
