Volumio 3. SSH enabled.
I get this error log when i attempt to ssh.
error: Could not load host key: /etc/ssh/ssh_host_rsa_key
error: Could not load host key: /etc/ssh/ssh_host_dsa_key
error: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
Did you make any changes to the default password for Volumio?
if yes, restore the default password.
Try disable and enable ssh <ip-address>/dev
Does this solve the problem?
If no,
Connect a monitor and keyboard to your device. Press CTRL + ALT + F1
Login to volumio with the default credentials.
then execute the following commands:
sudo rm -f /etc/ssh/ssh_host*
sudo dpkg-reconfigure openssh-server
If this still doesn’t solve the issue, you need to reflash your SD
I’m running Volumio 3 on a laptop (x86).
CTRL + ALT + F1 does nothing.
I can’t get to a command line to execute those commands
try ALT+F4
no joy…
hang on… that worked. Ill try those commands now
Wow. Thankyou so much. Worked a charm! that alt+F4 was just what i needed.
Regards
How do i get back to the UI from the command line?
just type sudo reboot
or ctrl-alt F2
