I started to rip my CD box with the complete works of Verdi. The music files (ogg) are placed on a NAS, , and I make playlists in Volumio.
I didn’t notice any problems until I reached Rigoletto, where all files except the Sinfonia have ‘"’ in the names. And he playlist only contained the one file without.
I can’t play the file either, so it’s not only a playlist problem.
Is this a knwon limitation? Can it be fixed (other than renaming all the files), or does a workaround exist?
Tried volumio from this summer, and upgraded to 2.348 to test, but problem persists.
From the 9 cd’s i’ve ripped to aiff all the foldernames and filenames containing apostrophes are not visible after ‘Update’ and ‘Rescan’ in the Music Library. Reboot didn’t solve the issue either.
Volumio 2.348, Rpi3, Hifiberry (XLR), Music Library on Nas.
I noticed the problem too and BTW there is also a problem with colons ( in the filename which is commonly used with classical music (I usually rip CDs with a Linux notebook, maybe this doesn’t happen on Windows) .
I solved these issues with a shell command which replaces quotation marks and colons by spaces.
