hello,
I am strugling trying to play hires audio on my raspberry/volumio config.
the media comes from qobuz studio masters library.
Its a wma 24/88 file.
I first faced a situation where ffmpeg generated systematically a seg fault.
I regenerated a new volumio confg, update/upgrade and everything : ffmpeg runs now normally.
but when trying to play through volumio/mpd : doexsnt work.
when processing the file with ffmpeg which, I believe, is delegated by mpd to process the media, I got the following message :
ffmpeg -i 01-13-Daft_Punk-Contact-SMR.wma
ffmpeg version 0.8.10-6:0.8.10-1+rpi1, Copyright © 2000-2013 the Libav developers
built on Mar 22 2014 02:13:15 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[asf @ 0x5a2440] max_analyze_duration reached
Input #0, asf, from ‘01-13-Daft_Punk-Contact-SMR.wma’:
Metadata:
album : Random Access Memories (Ãdition Studio Masters)
track : 13
TrackTotal : 13
Duration: 00:06:21.52, start: 0.000000, bitrate: 3163 kb/s
Stream #0.0(fre): Audio: c[1][0][0] / 0x0163, 88200 Hz, 2 channels, 1152 kb/s
At least one output file must be specified
can someone tell me how to circumvent/close this issue ?
thanks
