I have a Ravpower file hub. Using Sonos, this is mounted via //RP-WD03/SDCard_Volume1
There are no username or password set.
I’ve tried the same syntax in Volumio - but using the Ravpower IP address. I leave all other options blank. This fails to mount.
Any ideas.? Some thoughts… Do I need to specify username as guest? I’m assuming that the cifs protocol is correct?
