Can't install Touch display plugin
Fresh install with the last volumio version on a rpi 3 a+ and a 256gb sd card, everything works, but when i try to install the touch display plugin from the web interface : it keeps failing at 70% and always send this log :
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
Création de l'emplacement de destination
Décompression du plugin
Vérifier que le plugin est adapté à cette version de Volumio The plugin can be used with this version of Volumio
Vérification des doublons
Copie du plugin à destination
Installation des utilitaires nécessaires
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Installing graphical environment
The following additional packages will be installed:
keyboard-configuration libegl-mesa0 libegl1 libegl1-mesa libepoxy0 libevdev2
libfontenc1 libgbm1 libgudev-1.0-0 libinput-bin libinput10 libmtdev1
libpciaccess0 libunwind8 libutempter0 libwacom-bin libwacom-common libwacom2
libwayland-server0 libxaw7 libxcomposite1 libxfont2 libxft2 libxkbfile1
libxmu6 libxpm4 libxt6 libxxf86dga1 x11-utils x11-xkb-utils xbitmaps
xfonts-base xfonts-encodings xfonts-utils xserver-common xserver-xorg
xserver-xorg-core xserver-xorg-input-all xserver-xorg-input-libinput
xserver-xorg-input-wacom xserver-xorg-legacy xserver-xorg-video-all
xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-fbdev
xserver-xorg-video-nouveau xserver-xorg-video-radeon xserver-xorg-video-vesa
xterm
Suggested packages:
pciutils mesa-utils xfonts-100dpi | xfonts-75dpi xfonts-scalable xinput
firmware-amd-graphics xserver-xorg-video-r128 xserver-xorg-video-mach64
xfonts-cyrillic
The following NEW packages will be installed:
xfonts-base xfonts-encodings xfonts-utils xinit xserver-common xserver-xorg
xterm
0 upgraded, 50 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/19.0 MB of archives.
After this operation, 32.0 MB of additional disk space will be used.
Selecting previously unselected package keyboard-configuration.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 34963 files and directories currently installed.)
Preparing to unpack .../00-keyboard-configuration_1.193~deb10u1_all.deb ...
Unpacking keyboard-configuration (1.193~deb10u1) ...
Selecting previously unselected package libxxf86dga1:armhf.
Preparing to unpack .../01-libxxf86dga1_2%3a1.1.4-1_armhf.deb ...
Unpacking libxxf86dga1:armhf (2:1.1.4-1) ...
Selecting previously unselected package libwayland-server0:armhf.
Preparing to unpack .../02-libwayland-server0_1.16.0-1_armhf.deb ...
Unpacking libwayland-server0:armhf (1.16.0-1) ...
Selecting previously unselected package libgbm1:armhf.
Preparing to unpack .../03-libgbm1_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
Selecting previously unselected package libegl-mesa0:armhf.
Preparing to unpack .../04-libegl-mesa0_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libegl-mesa0:armhf (19.3.2-1~bpo10+1~rpt4) ...
Selecting previously unselected package libegl1:armhf.
Preparing to unpack .../05-libegl1_1.3.0-7~bpo10+1_armhf.deb ...
Unpacking libegl1:armhf (1.3.0-7~bpo10+1) ...
Selecting previously unselected package libegl1-mesa:armhf.
Preparing to unpack .../06-libegl1-mesa_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libegl1-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
dpkg-deb (subprocess): failed to create directory: Structure needs cleaning
dpkg-deb: error: tar subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/07-libepoxy0_1.5.3-0.1_armhf.deb (--unpack):
dpkg-deb --control subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/08-libevdev2_1.6.0+dfsg-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/09-libfontenc1_1%3a1.1.3-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/10-libgudev-1.0-0_232-2+rpi1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/11-libwacom-common_0.32-1_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/12-libwacom2_0.32-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/13-libinput-bin_1.12.6-2+deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/14-libmtdev1_1.1.5-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/15-libinput10_1.12.6-2+deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/16-libpciaccess0_0.14-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/17-libunwind8_1.2.1-10~deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/18-libutempter0_1.1.6-3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/19-libwacom-bin_0.32-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/20-libxt6_1%3a1.1.5-1+b3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/21-libxmu6_2%3a1.1.2-2+b3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/22-libxpm4_1%3a3.5.12-1+deb10u2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/23-libxaw7_2%3a1.0.13-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/24-libxcomposite1_1%3a0.4.4-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/25-libxfont2_1%3a2.0.3-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/26-libxft2_2.3.2-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/27-libxkbfile1_1%3a1.0.9-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/28-x11-utils_7.7+4_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/29-x11-xkb-utils_7.7+4_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/30-xbitmaps_1.1.1-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/31-xfonts-encodings_1%3a1.0.4-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/32-xfonts-utils_1%3a7.7+6_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/33-xfonts-base_1%3a1.0.5_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/34-xinit_1.4.0-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/35-xserver-common_2%3a1.20.4-1+rpt4+deb10u9_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/36-xserver-xorg-core_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/37-xserver-xorg-video-amdgpu_18.1.99+git20190207-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/38-xserver-xorg-video-radeon_1%3a19.0.1-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/39-xserver-xorg-video-ati_1%3a19.0.1-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/40-xserver-xorg-video-fbdev_1%3a0.5.0-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/41-xserver-xorg-video-nouveau_1%3a1.0.16-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/42-xserver-xorg-video-vesa_1%3a2.4.0-1+b1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/43-xserver-xorg-video-all_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/44-xserver-xorg-input-libinput_0.28.2-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/45-xserver-xorg-input-all_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/46-xserver-xorg-input-wacom_0.34.99.1-1+b6_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/47-xserver-xorg_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/48-xserver-xorg-legacy_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/49-xterm_344-1+deb10u2_armhf.deb (--unpack):
Errors were encountered while processing:
Installation of xinit failed
Plugin failed to install!
Cleaning up...
Removing dependencies
Package 'fonts-arphic-ukai' is not installed, so not removed
The following packages will be REMOVED:
keyboard-configuration* libegl-mesa0* libegl1* libegl1-mesa* libgbm1*
libwayland-server0* libxxf86dga1*
0 upgraded, 0 newly installed, 7 to remove and 2 not upgraded.
7 not fully installed or removed.
After this operation, 3313 kB disk space will be freed.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 35026 files and directories currently installed.)
Removing keyboard-configuration (1.193~deb10u1) ...
Removing libegl1-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libegl1:armhf (1.3.0-7~bpo10+1) ...
Removing libegl-mesa0:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libwayland-server0:armhf (1.16.0-1) ...
Removing libxxf86dga1:armhf (2:1.1.4-1) ...
Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
Purging configuration files for libxxf86dga1:armhf (2:1.1.4-1) ...
Purging configuration files for keyboard-configuration (1.193~deb10u1) ...
Package 'fonts-arphic-gbsn00lp' is not installed, so not removed
Package 'fonts-unfonts-core' is not installed, so not removed
Package 'fonts-ipafont' is not installed, so not removed
Package 'fonts-vlgothic' is not installed, so not removed
Package 'fonts-thai-tlwg-ttf' is not installed, so not removed
Package 'chromium-browser' is not installed, so not removed
Package 'openbox' is not installed, so not removed
Package 'xinit' is not installed, so not removed
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
Enabling login prompt
Done
Une erreur est survenue lors de l'installation du plugin Error
Removing temporary directory /tmp/touch_display-W0VFEAddV2
I already read plenty of threads about it, but id like to see if someone understand my log.
2 posts were merged into an existing topic: [PLUGIN] Touch Display
