Can't find my wireless network
I’m running a Raspberry 3B with a HifiBerry on top and it works excellent as long as I have the network cable connected.
However, I cannot find my own wireless network in the list! I do see all my neighbors networks, but not mine!
Also, I cannot connect to it manually either.
I can connect to Volumio using Hotspot from my phone, but again: I cannot find my wireless network in the list.
I’ve tried everything, does anyone have an idea?
My Router is an Asus RT-AC87
Is your wifi setup as a hidden network?
Did you set up your router only activating the 5 Ghz wifi? Raspi3 does not support 5ghz.
That’s the first things that come to mind.
Is your wifi AP on channels 12/13 ?
You may have to set CRDA according to your country.
Last resort, try to reboot your wifi AP…
