I’m trying to upgrade a Pi 3 to v 2.141 (re-flashing the card).
I can connect via the ethernet connection without any trouble. My wifi network is detected and I entered the password as normal. But when I unplug the ethernet, no connection is made to the wifi. Restarting the Pi when unplugged from the router doesn’t help matters.
When I try to turn on wireless networking and click save it reverts to ‘off’ after a refresh.
I haven’t experienced this issue with any previous version of Volumio on the same network/ Pi. Is this a known problem? What should I be doing to fix this?
Many thanks.
