Hello, I’m having trouble trying to connect to my work’s WPA2 Enterprise network with Volumio on my Pi 4B.
I tried editing the wpa_supplicant.conf file but my issue is that every time I edit it and then change something in volumio’s network settings such as adding a new network, it overrides the whole file with what seems to be volumio’s own database of saved networks. Can anyone point me in the direction of that database or provide a better solution, ideally I’d still like to be able to add networks via volumio’s UI.
This is what I’m attempting to add to wpa_supplicant.conf:
network={
ssid="SSID"
scan_ssid=1
key_mgmt=WPA-EAP
eap=PEAP
identity="username"
password="password"
phase2="auth=MSCHAPV2"
Thanks!
