Can't change samplerate_converter
Hi all,
i am trying to change the samplerate_converter from fastest to best option through the web ui but it seems that it’s impossible. Whatever I choose, mpd restards and it remains the “fastest” option.
I manually edited /etc/mpd.conf, i changed it, i restarted mpd daemon and, although i do not know if this setting is enabled, volumio is playing my audio files normally. Through the ui settings, fastest remains the selected option.
Is it a web ui bug?
Bump.
I have the same problem. My Volumio version is Beta1.4
One more vote for this bug, on 1.5
Hi guys,
I’ve fixed the issue. Please place the attached mpd-config.php in /var/www/, and the attached mpd-config.html in /var/www/templates.
Enjoy!
mpd-config.zip (5.58 KB)
Great! If you don’t mind, could you post a diff of what changed? If everything checks out, we can incorporate your fix into the next release. Alternatively, you can push the change to a git repo, and we can merge from there.
Sure thing, I’ll have to paste here because I have no idea what I’m doing with Git.
I’ll get back to you with the diffs shortly
It looks like my update has already been rolled into the Master :slight_smile:
