Hi all,
Apologies for what is likely to be a dumb question.
I’m trying to get Volumio working on my Pi.
However, I can’t get past the boot screen to launch the user interface.
Attached is the screen I get frozen on. (Booting progresses to the Volumio graphic made out of keyboard characters and the explanation there’s no warranty).
Am I missing something obvious or is there a problem?
Dave
Did you tried on your computer write http://volumio.local?
(Actually, I dont know if volumio starts in some graphical thing, but I dont think so)
Yes, you’ve connected to the Pi as a terminal, and that’s what you’ll get, eventually leading to a shell prompt. If you connect to the web user interface via a browser and the URL volumio.local, you should see the main screen,
Chris M
I don’t understand Chris comment.
Is it means I should link to internet when boot Volumio with Raspberry Pi?
Or I can only boot into terminal mode not GUI?
