I’m new to all of this, so sorry if this is the wrong way to do things.
My Pi2/HifiBerry DAC+ setup runs with only wifi (through the official rpi-wifi-dongle using “brcmfmac” as a driver).
This morning I updated to v2.029 through the webUI and restarted as per instructions. After this I can’t access the pi through the WebUI, but I can access the pi through SSH and I can ping urls. If I access 192.168.1.96:3000 I get the spinning wheel (see this screenshot), but the buttons at the bottom have weird holding-text.
Does anyone have an idea how to fix this? I tried restarting mpd and restarting the pi, but it didn’t help. Don’t hesitate to ask, if you need some kind of log-file or something.
The only non-stock modification I’ve made is to disable power-management on the wifi, since resume broke the connection. Thank you for making a lovely piece of software!
volumio@volumio:~$ sudo journalctl -f
-- Logs begin at Sat 2016-11-19 09:43:08 UTC. --
Nov 19 12:53:48 musik systemd[1791]: Starting Basic System.
Nov 19 12:53:48 musik systemd[1791]: Reached target Basic System.
Nov 19 12:53:48 musik systemd[1791]: Starting Default.
Nov 19 12:53:48 musik systemd[1791]: Reached target Default.
Nov 19 12:53:48 musik systemd[1791]: Startup finished in 40ms.
Nov 19 12:53:48 musik systemd[1]: Started User Manager for UID 1000.
Nov 19 12:53:48 musik sshd[1785]: lastlog_openseek: Couldn't stat /var/log/lastlog: No such file or directory
Nov 19 12:54:04 musik sudo[1804]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Nov 19 12:54:04 musik sudo[1804]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Nov 19 13:00:06 musik systemd[1]: Found device /dev/ttyAMA0.
Nov 19 13:00:06 musik kernel: snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
Nov 19 13:00:06 musik kernel: snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
Nov 19 13:00:10 musik dhcpd[421]: Wrote 1 leases to leases file.
Nov 19 13:00:10 musik dhcpd[421]: Not configured to listen on any interfaces!
Nov 19 13:00:10 musik dhcpd[421]: If you think you have received this message due to a bug rather
Nov 19 13:00:10 musik dhcpd[421]: than a configuration issue please read the section on submitting
Nov 19 13:00:10 musik dhcpd[421]: bugs on either our web page at www.isc.org or in the README file
Nov 19 13:00:10 musik dhcpd[421]: before submitting a bug. These pages explain the proper
Nov 19 13:00:10 musik dhcpd[421]: process and the information we find helpful for debugging..
Nov 19 13:00:10 musik dhcpd[421]: exiting.
Nov 19 13:00:10 musik dbus[377]: [system] Successfully activated service 'org.freedesktop.UDisks'
Nov 19 13:00:10 musik systemd[1]: Started Disk Manager (legacy version).
Nov 19 13:00:10 musik dbus[377]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkitd.service'
Nov 19 13:00:10 musik systemd[1]: Starting Authenticate and Authorize Users to Run Privileged Tasks...
Nov 19 13:00:10 musik polkitd[425]: started daemon version 0.105 using authority implementation `local' version `0.105'
Nov 19 13:00:10 musik dbus[377]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 19 13:00:10 musik systemd[1]: Started Authenticate and Authorize Users to Run Privileged Tasks.
Nov 19 13:00:11 musik kernel: random: nonblocking pool is initialized
Nov 19 13:00:11 musik udisks-glue[332]: Device file /dev/mmcblk0p3 inserted
Nov 19 13:00:11 musik udisks-glue[332]: Device file /dev/mmcblk0 inserted
Nov 19 13:00:12 musik ntpd[391]: Deferring DNS for 0.debian.pool.ntp.org 1
Nov 19 13:00:12 musik ntpd[391]: Deferring DNS for 1.debian.pool.ntp.org 1
Nov 19 13:00:12 musik ntpd[391]: Deferring DNS for 2.debian.pool.ntp.org 1
Nov 19 13:00:12 musik ntpd[391]: Deferring DNS for 3.debian.pool.ntp.org 1
Nov 19 13:00:12 musik ntpd[429]: signal_no_reset: signal 17 had flags 4000000
Nov 19 13:00:12 musik isc-dhcp-server[409]: Starting ISC DHCP server: dhcpdcheck syslog for diagnostics. ... failed!
Nov 19 13:00:12 musik isc-dhcp-server[409]: failed!
Nov 19 13:00:12 musik systemd[1]: isc-dhcp-server.service: control process exited, code=exited status=1
Nov 19 13:00:12 musik systemd[1]: Failed to start LSB: DHCP server.
Nov 19 13:00:16 musik dhcpcd[543]: version 6.0.5 starting
Nov 19 13:00:16 musik wireless.js[412]: dhclientstderr: dhcpcd[543]: version 6.0.5 starting
Nov 19 13:00:16 musik kernel: brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Nov 19 13:00:16 musik kernel: brcmfmac: brcmf_add_if: ignore IF event
Nov 19 13:00:16 musik kernel: brcmfmac: power management disabled
Nov 19 13:00:16 musik wireless.js[412]: wpa supplicantstderr: ioctl[SIOCSIWENCODEEXT]: Invalid argument
Nov 19 13:00:16 musik wireless.js[412]: wpa supplicantchild process exited with code 0
Nov 19 13:00:17 musik smbd[592]: [2016/11/19 13:00:17.792298, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik smbd[522]: [2016/11/19 13:00:17.792298, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik smbd[592]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Nov 19 13:00:17 musik smbd[522]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Nov 19 13:00:17 musik smbd[592]: [2016/11/19 13:00:17.800835, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik smbd[522]: [2016/11/19 13:00:17.800835, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik smbd[592]: [2016/11/19 13:00:17.804274, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik smbd[522]: [2016/11/19 13:00:17.804274, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik winbindd[596]: [2016/11/19 13:00:17.911094, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik winbindd[596]: Unable to open new log file '/var/log/samba/log.winbindd-idmap': No such file or directory
Nov 19 13:00:17 musik winbindd[597]: [2016/11/19 13:00:17.996046, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:17 musik winbindd[597]: Unable to open new log file '/var/log/samba/log.wb-BUILTIN': No such file or directory
Nov 19 13:00:18 musik smbd[593]: [2016/11/19 13:00:18.052780, 0] ../lib/util/become_daemon.c:124(daemon_ready)
Nov 19 13:00:18 musik smbd[593]: STATUS=daemon 'smbd' finished starting up and ready to serve connections
Nov 19 13:00:18 musik smbd[598]: [2016/11/19 13:00:18.059520, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 19 13:00:18 musik smbd[598]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
