EDIT: Resolved - I explained the parameters that fixed my issue at the bottom of this post.
I have Volumio on Raspberry Pi, and a hard drive connected to my Asus Router (RT-AX88U).
I have tried everything, I cannot mount the drive on Volumio. I had already struggled 2 years ago and can’t remember the settings I had entered… (I tried vers=2.0 and 3.0 too, cifs vs nfs…)
Here is my router drive information:
That’s the settings I used:
And that’s the error message I get…
EDIT: RESOLVED: I had to use cifs instead of cfs. 2-in my network drive, I had to remove the the first part of the path.
Now it works
