recently, I changed my Qobuz subscription from Studio to Sublime+. My understanding is
that Sublime+ encompasses Studio.
But now login to Qobuz from the MyMusic tab in Volumio settings fails. Is this a bug or a feature?
If the latter, I would need to downgrade from Sublime+ to Studio which doesn’t make sense.
Is this a known problem?
Hello
That was exactly the same for me.
Logout (although you are not logged in) and then login again.
For me this was the help and since then it works fine.
Yes, tried this, still no luck. Is this a Volumio problem or Qobuz?
I CAN log into the desktop via Windows so my password and username look to be ok.
There does not seem to be any confirmation when I log in. There is a pop-up that says logging in but No error message. The my music page just continues to show the login screen. When trying to play Qobuz it says 'can not read account
Ok, ome significant progress…I flashed a new version of Qobuz and can now login, HOWEVER …im only getting 16 bit yet my sub is 24bit, did i miss a setting?
Thanks for your support by the way, very much appreciated.
