Hi, everybody.
I used to listen to the music using Volumio installed RPi4.
I set Now Playing plug in, and want to display the weather data in Idle Screen.
But I can display only time data.
I setup the Geographic Coordinates, and OpenWeatherMap API Key.
But, in the volumio, I can not display the weather data in idle screen.
Please, let me know the method to display the weather data in Idle Screen.
Thank You.
Kwon.
In the plugin settings, I entered your coordinates 37.2635727,127.0286009
and it worked.
And I assume you also enabled “Show Weather”?
Hi! patrickkfkan
I appreciate your testint
I checked the setup and retry, rebooting.
but I cannot still display weather data.
In my thought, there is two point to cause this problem
One is my API key, the other is my network setup.
My API key is “2480bc2e100f1c9cbba8e29b82361b1f”
Would you test my API key?
sincerely yours!
Kwon.
Your API key doesn’t work. I got this error in the logs:
UnhandledPromiseRejectionWarning: Error: {"cod":401,"message":"Invalid API key. Please see http://openweathermap.org/faq#error401 for more info."}
Try generating a new API key. Also, check in your email for any activation messages. I don’t remember if it needs activating - it’s been quite a while since I generated mine…
Hi! patrickkfkan,
Thank you your tesing,
I checked my API key is in active,
I will generate new API key.
Thanks again!
Kwon.
I have exactly the same problem.
Why? You don’t need an API key for weather now (v0.3.7)
I’m running Volumio 3.378, the latest I can get, but see no way to determine plug in version. If I delete the plug in and re-install to see if it’s a newer version, will I lose all my custom settings?
If you delete the plugin you will lose all its settings. You can just update.
there is probably something wrong with API. on my all Volumio players starting today Now Playing plugin stoped to show weather info.
log:
error: [now-playing] Error fetching https://openweathermap.org/data/2.5/weather?appid=5796abbde9106b7da4febfae8c44c232&lat=48.148598&lon=17.107748: Error: Response error: 401 - Unauthorized
at fetchPage (/data/plugins/user_interface/now_playing/dist/lib/api/openweathermap/index.js:29:15)
Same here. This happens regularly even without software updates. Hopefully this is being addressed.
