I’m using Volumio on a Pi4B wirelessly. After shutting down my pi within the app I cannot get back into Volumio without having to set it back up again using an ethernet cable. The pi no longer shows on the network. I don’t see the hotspot option to reconnect wirelessly.
Are there settings within the app that I can set to avoid this problem?
Ok, thanks. I’ve got music on a small ssd but being powered on all the time it gets quite warm. Since I may go 1-2 weeks without listening to my system, I was thinking shutting down volumio/pi would be better for longevity. I guess I’ll just leave it on unless a “sleep” function is possible.
