Hey there,
I just updated Volumio to 3.703 (previously on 3.6xx) and it seems it’s broken my Python’s socket connection to Volumio on localhost (I use it to control Volumio using physical buttons and a fourteen-segment display).
Here is the kind of script that I used to run to initialize the socket connection:
from socketIO_client import SocketIO
socket = SocketIO('localhost', 3000)
socket.on('connect', self._on_connect)
socket.on('disconnect', self._on_disconnect)
socket.on('reconnect', self._on_reconnect)
socket.on('pushState', self._on_state_response)
socket.on('getState_response', self._on_state_response)
socket.on('pushQueue', self._on_queue_response)
socket.on('getQueue_response', self._on_queue_response)
Since I updated Volumio I’m getting this error:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.7/dist-packages/socketIO_client/__init__.py", line 353, in __init__
resource, hurry_interval_in_seconds, **kw)
File "/usr/local/lib/python3.7/dist-packages/socketIO_client/__init__.py", line 54, in __init__
self._transport
File "/usr/local/lib/python3.7/dist-packages/socketIO_client/__init__.py", line 62, in _transport
self._engineIO_session = self._get_engineIO_session()
File "/usr/local/lib/python3.7/dist-packages/socketIO_client/__init__.py", line 76, in _get_engineIO_session
transport.recv_packet())
StopIteration
Would you have any idea how to fix it? Or is it possible to downgrade to the previous release?
Thank you for your help!
