Very Newby from Germany. As Synology no longer supports Logitech Media Server, I looked for a solution because there a several musicplayer as Squeezboxradio etc.
So I got me a raspberry PI 4 (4 GB) and suceeded in installing volumio.
After that I installed the plug-in logitech media server.
After long during trials to set my DiskStation as “Source”, I found out that the players find my music files. But not the way I intended. It is very uncomfortable and a lot of klicks to get there and back to “radio”-music.
I did everything to mount an NFS Share like descriped in the help doc. Even try some options etc.
But nothing works.
Despite following the setup guide, I suspect this is a problem with your NFS settings on your NAS. Can you do some screen shots of your settings please?
You seem to be chopping and changing between cifs and nfs (from the screen shots). Please stick to one or the other, or you are just making problem-solving more complicated.
I’m totally confused now about whether you are trying to mount a cifs or a nfs share. The mechanisms for these two are both very different, and they both have different requirements.
Your first screenshot shows you trying to mount a cifs share.
The second screenshot show you trying to mount a nfs share.
Your last post quotes an error about a cifs share.
I’ll let someone else try and follow your thread ;).
let’s start from scratch. You’re switching between CIFS and NFS and wonder why it is not working.
Please answer the following questions. Without it I can’t support you.
Which protocol did you enabled on your NAS, CIFS and/or NFS?
If CIFS, which SMB version is supported by your NAS (V1 and/or V2 and/or V3)?
Which user has been setup on your NAS to access this share (alexmusic?)
Is this user setup for NFS or CIFS or Both?
What is the path of this share, as normally the “volume1” should not be part of this, Please validate the exact path from a windows machine. it’s either \192.168.178.21\music or \192.168.178.21\volume1\music
Thank you for your help! If the thing is now working, everything is OK.
Anyway. I found out that the Logitech Media Server on Rpi is just half the solution for my problem with the squeezebox devices.
If I switch to “library volumio” I may hear my stored music. But it’s not possible to listen to Internet radio stations with the devices.
As I told in my first post, I’d like to substitute my LT Media Server on the NAS because it’s not longer supported by Synology.
Sorry. Take it all back. Even radio function with preset buttons on my squeezebox radio is working. Now after indexing was finished, I found everything as used to.
I just finished to change drives and set up my friend’s Synology DS212+. I faced with similar problem. During debugging I discovered that Volumio on Tinker Board required “vers=3.0” but x86 machine worked without it.
