New install of the latest version on the RP3. If I change the interface to “classic” or “contemporary” and click save my selection is ignored and the interface stays in manifest. Tried factory reset and several restarts. Still stuck in manifest. Any workarounds?
Take a look. Maybe it’s the same problem.
The solution from the other post does work. With “manifest” selected choose save, choose the one you want and choose save again.
Apologies for the duplicate post, but at least there is another post about this so that others will know what to do.
Why not create those config files from the beginning to avoid the bug or create a simple logic if not present it will be created? Hello!??!
