Cannot adjus tvolume above 58 vi IR when using click settings 1 or 2 with Natural volume curve mode
Prerequisites
Volumio Information
volumio@volumio:~$ cat /etc/os-release
PRETTY_NAME=“Raspbian GNU/Linux 8 (jessie)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“8”
VERSION=“8 (jessie)”
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/”
SUPPORT_URL=“RaspbianForums - Raspbian”
BUG_REPORT_URL=“RaspbianBugs - Raspbian”
VOLUMIO_BUILD_VERSION=“168ba7444df98cd868db72f24faec0b6346489cc”
VOLUMIO_FE_VERSION=“cad4eff7365bdee75d9502abc18273965a249393”
VOLUMIO_BE_VERSION=“dca65ba111e830b1b99f74e359f9903dd5002680”
VOLUMIO_ARCH=“arm”
VOLUMIO_VARIANT=“volumio”
VOLUMIO_TEST=“FALSE”
VOLUMIO_BUILD_DATE=“Wed Jan 20 19:06:01 CET 2021”
VOLUMIO_VERSION=“2.868”
VOLUMIO_HARDWARE=“pi”
VOLUMIO_HASH=“853dd7d4a9e86b0794692e4c1134e4e3”
Volumio Version: 2.868
Hardware: Pi 4
DAC: xmos xu208 interface
Debug Log
Steps to Reproduce
I went back to the 2.861 version. The volume control bug is still there as well.
  1. goto settings\playback options\volume options, set the volume control for “natural” (tested with hardware mixer). Bug does not appear when set to “linear” volume control
  2. change the “one click volume steps” settings = 1 or 2 causes the problem. Changing to Steps=4 or greater work fine.
  3. use IR plugin module and IR control or use /usr/local/bin/volumio volume plus from the ssh console. Volume cannot be raised above 58.
Additional Information
