peterz
September 20, 2018, 7:23pm
1
for some reason i cannot access GUI anymore. It worked a few days ago, but then it freezed during use. I was tired so i left it for another time and went to sleep.
I can ping or ssh Volumio (eth0 or wireless ip).
I can connect to Volumio via ssh.
I haven’t done any configuration changes for the last few months.
All that was changed was ISP provider, but internal network and routing stayed the same as it was before.
I rebooted numerous times, restarted services switched to wired or wireless only, no luck.
I considered updating volumio but that can only be done via GUI…
The only thing that’s odd is that /static fs is at 100% full. Is that a problem?
mpd.log:
Sep 20 18:53 : zeroconf: No global port, disabling zeroconf
volumio.log is empty.
Please do suggest something. I’m quite desperate.
Regards, Peter
chsims1
September 21, 2018, 8:59am
2
Check that it has not started it’s hotspot, and/or send a log.
HI,
here is the same Problem after Update to 2.457…
Connected via Cable and fixed IP. No wireless.
volumio
September 21, 2018, 11:17am
4
Please send logs
or if you can’t
connect via ssh and do
sudo journalctl -f
you should see where it crashes, copy this section and send to us
peterz
September 21, 2018, 6:31pm
5
Attached is journal section that’s constantly repeating. (or should i paste the section in post?)
journal.log.zip (1.63 KB)
Sep 21 18:23:51 volumio volumio[2639]: info: Loading plugin "youtube"...
Sep 21 18:23:51 volumio volumio-remote-updater[621]: [2018-09-21 18:23:51] [connect] Successful connection
Sep 21 18:23:53 volumio volumio[2639]: module.js:590
Sep 21 18:23:53 volumio volumio[2639]: throw err;
Sep 21 18:23:53 volumio volumio[2639]: ^
Sep 21 18:23:53 volumio volumio[2639]: SyntaxError: /data/plugins/music_service/youtube/authToken.json: Unexpected end of JSON input
Sep 21 18:23:53 volumio volumio[2639]: at Object.parse (native)
Sep 21 18:23:53 volumio volumio[2639]: at Object.Module._extensions..json (module.js:587:27)
Sep 21 18:23:53 volumio volumio[2639]: at Module.load (module.js:487:32)
Sep 21 18:23:53 volumio volumio[2639]: at tryModuleLoad (module.js:446:12)
Sep 21 18:23:53 volumio volumio[2639]: at Function.Module._load (module.js:438:3)
Sep 21 18:23:53 volumio volumio[2639]: at Module.require (module.js:497:17)
Sep 21 18:23:53 volumio volumio[2639]: at require (internal/module.js:20:19)
Sep 21 18:23:53 volumio volumio[2639]: at Object.<anonymous> (/data/plugins/music_service/youtube/index.js:19:13)
Sep 21 18:23:53 volumio volumio[2639]: at Module._compile (module.js:570:32)
Sep 21 18:23:53 volumio volumio[2639]: at Object.Module._extensions..js (module.js:579:10)
Sep 21 18:23:53 volumio volumio[2639]: at PluginManager.loadPlugin (/volumio/app/pluginmanager.js:117:25)
There is your culprit! There is a syntax error in /data/plugins/music_service/youtube/authToken.json
peterz
September 21, 2018, 6:57pm
7
Yes, i saw that - is there a way i can skip this plugin temporarily without gui access?
/data/plugins/music_service/youtube/authToken.json is an empty file.
nano /data/configuration/plugins.json
and find your plugin and set it’s enabled to false.
There is probably a simple oneliner with jq…
balbuze
September 21, 2018, 7:06pm
9
you try :
systemctl stop volumio
nano /data/configurations/plugins.json
and set the youtube plugin on false ad stopped
"youtube": {
"enabled": {
"type": "boolean",
"value": false
"status": {
"type": "string",
"value": "STOPPED"
save andrestart volumio
systemctl start volumio
peterz
September 21, 2018, 7:14pm
10
Great! I have GUI access again.
Thank you guys!
So what is the next step.
Should i try to troubleshoot this plugin? Reinstall it? Maybe update this plugin and/or the Volumio system?
I recall seeing quite a few people having issues with the plugin, search around!
the mistake is gone by itself…!? I will keep watching…
