I I upgraded superstar as I wanted to use the analogue input feature on my DAC+ ADC. I was disappointed to learn that although I could use the input to listen to analogue sources on the connected device, it was not possible to listen to this on other volumio devices on the same network.
there are ways of doing it but they require a lot of messing around with add-ons and I just wanted a simple option built-in to Volumio.
Is it still the case that I can only listen to the analogue input on the connected device or has functionality been added to easily allow the analogue audio to be streamed to another Volumio device?
Looks like Iāll be cancelling my Superstar subscription as well. I was under the impression that we could run up to 6 devices āsimultaneouslyā, and also get better sound quality, but thatās not the case at all. If you want better sound quality, you have to buy into the Highresaudio service for roughly $313 US per/year or one of the other streaming services to get better sound quality. The other problem I have is that even if you do have more than 1 device, they have to have the same DACās. I have 1 Raspi with a HiFiBerry Digi + Pro Dac, and the other with a HiFiBerry + Pro. If you switch to the Raspi that is configured for the Digi and then switch back to Pro, it wont play because the āAudio Outputā configuration doesnāt change with it.
I still like my Volumio, its just that the Superstar package is not for me. However, if in the future we will be able to run true āMulti-Room devices simultaneouslyā, then Iāll for sure up-grade my subscription.
There is no way Iād ever pay for a Volumio subscription. The Android app is pretty much unusable. It just doesnāt work. all Iām using volumio for is Spotify connect which is a shame because it could be so much better and Iād love to be able to to use it for web radio but itās just not worth the hassle. It all works fine when I access it through my laptop but Iām hardly ever on my laptop. If I canāt operate it from a mobile device itās pointless.
Also, as far as Iām aware itās still not possible to stream from a DACās analogue input to another Volumio device in the same network. I canāt really see the point of having the analogue input function unless you can do this. This alone certainly isnāt worth paying a superstar subscription for either way!
Hi, I think youāre getting it wrong⦠You can use 6 devices and they can be with different DACs. Maybe youāre having another issue, which we can help you with. Just contact us at support at volumio.org
We are working hard to improve the app. As of now, the Android version is really slow (it has to do with the webview on React Native, it works great on iOS but really bad on Android).
Did you try writing the IP in the mobile browser? That works just fine.
This feature is 90% complete and we plan to release it within few months, together with the multiroom synced playback feature.
I too find the Android app works okay.
Itās not slow or lacking for what I want to do.
I only use Qobuz with it and RPi/Kali reclocker.
I have to use the Qobuz app to save songs to playlists and then Volumio can pick them up (bit round about)but it works.
I can access Volumio on my Win/Lin laptops by typing the IP address one of the devices into my browser address bar. I can then use all the functions of Volumio perfectly well on every device.
Itās flawless in fact.
The issue is definitely with the Android app for me unfortunately. Itās not just slow, for the most part itās just totally unresponsive. It just locks up and does nothing.
I can start a song playing using Spotify on my mobile device, if I select Spotify connect and point it to one of the devices this works well and is quite reliable or the most part.
There is an inofficial way to do that by creating an additional MPD output manually by editing mpd.conf
This has been mentioned somewhere here in the Forum years ago. (and it is working !)
You will loose OTA functionalty and donāt expect multiroom Synchronisation by doing soā¦. also it will not work with Sporify.
