Hi, I use volumio since last year, today ive disabled both wifi and cable with the result, that i can
t find volumio anywhere, even not in the router, no ip-adress.
What can I do now? There is no reset button, and the volumio hotspot was disabled (unfortunately).
the only thing you can do is connecting a monitor to the device and enable the network again.
If that is not possible, you need to start from scratch.
No chance, im not a programmer and my tv-monitor shows me an address that doesn
t work: rivo.local (127.0.0.1) Is there anybody in Stuttgart or near Stuttgart to help me?
So connect a mouse and go to Network and enable Ethernet again, reboot and the Rivo should obtain a ip.
I am not close to Stugart, it’s a 7 hours drive and I don’t understand that German dialect (Schwalbish??)
Do you have a Volumio Rivo? If so, you have dedicated support if you create a Support Ticket
I will ask the support, but I need a button combination for reset or something similar. I can`t get inside the program.
Look at page 10 in the manual.
please have a look here
